Results 1 to 22 of 22
Thread: vs commodore stalling
    vs Executive s1
    Oct 2009
    Unhappy vs commodore stalling
    hi have had a problem withe my vs stalling as you pull up to a set of lights when i have taken my foot of the accelerator. I have changed the tps sensor aswell as the both o2 sensors and fixing the earthing problem but still keeps doing it and not showing any code errors please help.
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    I am currently experiencing the same problem. It can be a whole host of different thing - the prime suspects being fuel pump and the crank angle sensor.
    In my case it look like the immobiliser is doing something strange so at the moment it has been bypassed until such time that I can take it to GMH and have installed a new BCM (+ new key heads). Hopefully that will fix it for good.
    vs Executive s1
    Oct 2009
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'd be doing the CAS first and then the DFI module. CAS is cheapest to fix.
    vs Executive s1
    Oct 2009
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    hako is on the mark. Change the cas.
    Mine was cutting out and the car cut out at 60kph.no code logged.
    Read this and have a read of my links in the thread.
    Bit of a read but worth it common fault.
    VS V6 Stalls at 90km/h
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    Vs Equip
    Jul 2008
    i had a similar problem around a year ago car would start and stall at random turned out to be the cam angel sensor just above the crank pulley and below the water pump the wires going to it where abit corroded so i taped them up and no more problem even did a few long trips 1000+ km and still good.
    vs Executive s1
    Oct 2009
    VS_Pete_1's Avatar
    Dec 2007
    Clean out the throttle body and reset the base idle.
    vs Executive s1
    Oct 2009
    vs Executive s1
    Oct 2009
    VS_Pete_1's Avatar
    Dec 2007
    bloody hell clean or replace maf sensor.
    With some help from members I hope we can get this right mate.
    VS_Pete_1's Avatar
    Dec 2007
    Injectors ok?
    fuel regulator?
    Have you changed the fuel filter?
    VS_Pete_1's Avatar
    Dec 2007
    Have you got a mate that has a good running car so you can swap parts to see what is the problem??
  15. #15
    VS_Pete_1's Avatar
    Dec 2007
    Did you read hako and my posts?
    Change the CAS first
  16. #16
    VS_Pete_1's Avatar
    Dec 2007
    Quote Originally Posted by VS_Pete_1 View Post
    Did you take the time to read all of this mate ?????
  17. #17
    vs Executive s1
    Oct 2009
    yeah i have read it all but think i am chasing a few problems with this car
  18. #18
    VS_Pete_1's Avatar
    Dec 2007
    ok I understand but u have to start somewhere and the CAS is the go.
    And put a new fuel filter on.
    Good luck.
    Sorry if I`m blunt but that is me.
    This is my first computer car and like you I know nothing but I read and asked questions and listened and acted, I have been lucky that I have found good advice.
    We are trying to help. I have read and read and hit my head to the wall but some people have helped me and I have helped them.
    Bloody cars.
  19. #19
    vs Executive s1
    Oct 2009
    have put new fuel filter on and have ordered cas will let u know. Then on the the next problems of it holding gears sometimes.
  20. #20
    VS Acclaim
    Nov 2007
    Quote Originally Posted by john221 View Post
    I had the exact same thing happen to me 3 weeks ago. It only happened when my fuel tank got below 1/3 though but the problem was that when i last filled up at BP there was what i believe water in the fuel so i went to shell and put 10L of E10 in and it fixed my problem.
  21. #21
    vs commodore
    Nov 2009
    hey mate i had the same problem it was the crank angle senor. i'll replace it and give a go i spent heaps on senors, fuel pumps and all kinds of shit but it ended up been the c.a.s
  22. #22
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    Quote Originally Posted by Acclaim96 View Post
    Mate, E10 is ethanol. Why would you use ethanol to clean out water? it turns to gel when it comes into contact with water. Now (if you did have water in there in the first place) You're gonna need a new fuel filter because it will be clogged with jelly-crap. If you have water in the fuel you drop the tank, not try to run it through.
    Also only stalling under 1/3 will have zero to do with water in the fuel and more to do with your fuel pump and swirl pot
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
  1. 98 Vt Commodore (stalling)
    By broomie21 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-11-2009, 11:00 PM
  2. Vs Commodore v6 Stalling
    By fb69 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-06-2009, 09:21 PM
  3. VS Commodore stalling
    By finch21 in forum V6 Development And Modification
    Last Post: 14-02-2009, 11:53 AM
  4. commodore stalling!
    By plasmid2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-01-2009, 03:15 PM
  5. vn commodore near stalling
    By riker in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-07-2006, 11:51 PM
