Results 1 to 24 of 24
Thread: upping transmision pressure.
    VS executive
    Jun 2009
    Default upping transmision pressure.
    ive heard its just a matter of turning a dial under/in the transmission box , is this correct and more details please if so.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If you mean tightening bands it cannot be done easily on the 4L60E Commodore transmission - there are "shift kits" but nothing you can do with the turn of a dial.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    no he means turning up the base pressure with the allen key headed screw under the shift solinoid
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by delcowizzid View Post
    So what does this do?
    в∞ѕтεכ √&
    Jul 2008
    NZ
    increases the whole base pressure of the trans to make up for wear and tear too much is bad but it can make a sloppy box like new again you can go too far and every gear is like a shiftkit and servo is in there and in the end the box goes
    VS executive
    Jun 2009
    yeh the box isnt sloppy at the moment i was just looking for an cheaper option than a shift kit , figured it would cause problems if upped too much but im not expecting shift kit like performanc, just something a bit better than i have now until i can get a shift kit done.
    im going too get the oil filter changed and a service done soon just because its due so what harm can be done by a few turns of an allen key while the box is open.
    vs executive s1/ vz berlina
    Mar 2008
    Its the pressure solenoid that can be adjusted not the shift solenoid, does your box delayed in shifting or maybe flaring?
    в∞ѕтεכ √&
    Jul 2008
    NZ
    the pressure adjuster is underneigth the the shift solinoid not the shift solinoid itself 1/8th to 1/4 of a turn should be plenty
    VS executive
    Jun 2009
    Quote Originally Posted by delfin82 View Post
    i have a tune in it from delco atm that shifts later under hard throttle, the box seems too slip a little bit when revving the guts out of it at higher rpm, its fine with the normal tune in it i just feel like im losing a bit of potential acceleration.
    by slipping at higher rpm i mean the engine screams and the tacho shoots up what seems faster than the car is actually pulling if you know what i mean once its shifted up its fine.
    i think its holding the rest of the mods back really.
    i should add that it does take a second too click into drive when in park as you asked , i have no idea what flaring is though.
    Mar 2008
    Quote Originally Posted by pillzor View Post
    Flaring is like the box hesitate to shift to next gear and when it does, it feels like slipping. delayed is what you mean when it put in drive, could be worn friction clutches, thats why it need more oil pressure to push the piston and clucthes to engage, seal in piston become hard already that why it losses line pressure, or by adjusting the pressure solenoid can help with it.
    VS executive
    Jun 2009
    cool thanks for that info, that sounds like what its doing under high revs.
    jashdown91 is offline Jashdown?
    VS Acclaim S1
    Nov 2008
    live in ballina, thats near byron bay, everyone knows where byron bay is
    My transmission is flaring. Everytime i put my foot down to go, it will flare like crazy and take it's time to shift. On top of this, is takes about a second or so to go from park to drive, or reverse to drive. Same problem as above?
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by sly_gen3 View Post
    so i guess a turbo locks both back wheels together? or is that a supercharger? thats what my cousin told me. Who also happens too be my girlfriend. She has 2 heads aswell.
    VS executive
    Jun 2009
    mines not really a problem , i just want it tighter too handle the extra power from the mods ive done.
    i mean it takes a second too select gear from park but on take off it holds fine, infact got wheelspin today for the first time while the motor and trans was cold ( i usually granny drive till its warmed up) , thats was going from 0 - 60 with third selected.. my problem only happens at higher rpm if im gunning.
    Mar 2009
    my auto has stopped selecting reverse gear.. was looking at getting a new transmission.. could adjusting the pressure fix my problem with selecting reverse? and if so how do i adjust it?
  15. #15
    2005 VZ Exec - 95 VS Executive
    Jan 2007
    Hmm this tightening is interesting... my box hesitates changing from park to drive or rev to drive and vice versa, a good 1 to 2 second delay, also when changing from 1st to 2nd and 3rd to second under heavy accelaration it slips like mad, car revs out then the gear engages and feels like i just dropped the clutch...
    is it possible this tightening could somewhat help my box at all or is my sloppy box just screwed?
  16. #16
    VS Acclaim
    Nov 2007
    Any pics of this?
  17. #17
    в∞ѕтεכ √&
    Jul 2008
    NZ
    nope.......
  18. #18
    VS Acclaim
    Nov 2007
    so where exactly is this the solenoid located? Can it easily be located to adjusted?
  19. #19
    в∞ѕтεכ √&
    Jul 2008
    NZ
    as far as im aware under the drivers side rear solinoid is the alen key headed bolt goes up into the trans its just obscured by the solinoid
  20. #20
    VS Acclaim
    Nov 2007
    so u turn it to clockwise?
    Anyone with pics? im still trying to think of where it is
  21. #21
    VS executive
    Jun 2009
  22. #22
    SirBedevere is offline Geek that gets laid
    VZ SS Ute
    Feb 2010
    QLD
    Giggle, I can see lots of exploded boxes thanks to you Pillzor!
    HG Kingswood CL Regal VP Commodore GSF600S Bandit
  23. #23
    QuickVRII95 is offline Banned
    Patent Pending 1995 VR Series II V6 Buick
    Sep 2010
    Quote Originally Posted by hako View Post
    Boosts Line Pressure & Gives Quicker Shifts At Higher Revs etc... Noticeable If Your Car Has More Power & It Doesn't Like To Shift Properly Between Higher Revs (Revs Gears Out etc)
    Try To Get As Much Info About The Desired Setting For "Your" Car (ie Power) ... Because You'll End Up Draining Your Transmission Fluid Again & Again, By Always Having To Take The Pan Off & Adjust It...
  24. #24
    Sep 2010
    dont turn it up too much if you do!
    KABOOM!!... Learnt That The Hard Way...
  1. Oil & Transmision Question
    By Dragz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-08-2006, 03:03 PM
  2. transmision not working
    By FadeToBlack in forum General
    Last Post: 23-01-2006, 11:36 PM
  3. transmision
    By myvrwagonneedshelp in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-01-2006, 11:45 PM
  4. VR New Transmision
    By tweaker in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-10-2005, 05:08 PM
  5. 5.0L V8 Cold air intake/Upping from 168kw to 185kw
    By smw757 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-06-2005, 04:55 PM
