Results 1 to 5 of 5
Thread: vr flooded - floor absolutly soaked.
    vt
    Oct 2008
    Default vr flooded - floor absolutly soaked.
    ok, car flooded up throu the hole where tranny is, the rubber boot wasnt in place when i went thru a flooded road.
    ive ripped up the carpet, its buggered. all the underlay is soaked.
    now theres another problem..
    on the chassis of the car inside, there are thease white moulded sheets that sticks to the floor, and it has more of that underlay underneath it, and thats soaked too.
    this white moulded sheets are all over the inside of the floor. They are stuck to the ground. They cover them rubber drain plug holes. Do you guys no what i mean ? Thease sheets are cracked in spots etc..
    well under that moulded sheets is more of that underlay, and thats soaked too.
    Has anyone got any ideas of what i can do ?
    i cant really rip that moulded sheet up ? i thought it would be there to quiten down noise from road.??
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    best bit is to wait for a hot day and leave the windows down a little, remove any floor mats and let it evaporate
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    you realise that insurance companies normally write off flooded cars for this reason. Ripping the sound deadening out is going to be a pain.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Just do as lemon-squeezy says - strip as much as you can and then windows/doors open with either a few fans or fan heaters to ventilate the car. Unless it was salt water that you went thru you should have no corrossion problems as under the sound proofing panel (white ones) it's painted.
    As long as no electrics got wet you will have no problems - if they get wet then the car is usually considered a write-off as Vee-ard says.
    vt
    Oct 2008
    Default shit..
    ive allready been airing it out for last 3 days
    ive had a little heater in there on the 33 degree day, was like 70 degreess in the car..
    poor little heater has been going long and stong for nearly 72hrs straight.. lol
    well im going to have to tear part of the sound deadning panels up, to dry out the underlay underneath that..
    the water only really collects in the lowest point under the deadening panels... so ill only have to rip out a 20cm x 20cm patch, so 4 patches in total..
    WHERE CAN I GET MORE OF THIS BODY DEADENING SHIZZZ ?? OR WHAT IS A GOOD ALTERNITIVE ??
  1. vr - flooded bad the other night..
    By macksvt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-11-2009, 12:09 PM
  2. Flooded Landrover
    By albert5268 in forum The Pub
    Last Post: 01-02-2009, 11:59 PM
  3. wet floor!!
    By schteven in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-10-2008, 06:55 PM
  4. sub in un-even floor in vs
    By crainy in forum Car Audio
    Last Post: 13-08-2005, 07:02 PM
