Results 1 to 4 of 4
Thread: How do I change front springs.
    Kirbs's Avatar
    Kirbs is offline L plater
    96 VS Executive S2
    Mar 2009
    Default How do I change front springs.
    Hey guys, I've done my rears but I know the fronts are harder/more tricky and I can't seem to find a how to.
    I can get springs in/out fine but I just need to know where to jack the car, What bolts to undo etc.
    My mates gonna lend me a hand so there will be 2 of use. Cheers
    Quote Originally Posted by levymetal View Post
    what a coincidence! the only way i can get my 2 year old son to sleep is if he's in the front seat of the car, no child seat, no seatbelt, and i'm doing 250km/h down the mornington peninsula freeway.
    jashdown91 is offline Jashdown?
    VS Acclaim S1
    Nov 2008
    live in ballina, thats near byron bay, everyone knows where byron bay is
    Easy as. you will need spring compressors however.
    1. Jack the car up from the crossmember and put jack stands under the chassis rails.
    2. rip your wheel off.
    3. locate the strut (not very hard) then find the two bolts down the bottom that connect it to the steering knuckle. The bold head i think is like 21 or 22mm, while the nut is 19mm. take the nuts off but leave the bolts in there to support strut.
    4. unclip the break cable and ABS line from the strut.
    5. Undo the 6 bearing plate nuts on the strut mount in the engine bay. once they are undone, you can pull out the two big bolts down the bottom of the strut, but support the rotor so its not hanging on the brake cable. Then you can manouvre the strut out.
    6. clamp the spring enough so that you can turn it around inside the strut. This is so when you undo the nuts on the top of the strut, they dont shoot through your wall and kill your neighbour. Then just take out all the part in the top of the strut (remembering exactly how they came out).
    then you just do the opposite of all this to put it back in, easy.
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by sly_gen3 View Post
    so i guess a turbo locks both back wheels together? or is that a supercharger? thats what my cousin told me. Who also happens too be my girlfriend. She has 2 heads aswell.
    Kirbs's Avatar
    96 VS Executive S2
    Mar 2009
    Thanks mate. Much appreciated.
    VS Acclaim S1
    Nov 2008
    no worries. you will also have to undo the bottom of the sway bar link where it connects to the sway bar. you might have to loosen the sway bar mounts if you can't manouvre the link pin out of the bar.
  1. how to change VT springs
    By Joel_91 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-02-2009, 06:01 PM
  2. change over front springs in VK V8
    By emmtee83 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-11-2008, 06:39 PM
  3. how to change springs in a vs
    By reggie_c2005 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-08-2008, 08:25 PM
