Results 1 to 11 of 11
Thread: axel seal busted again
    04 VZ sv8
    Nov 2009
    Default axel seal busted again
    hey guys i got a vs ute 5litre and in the past year and a bit i have had my rear left axel seal fixed twice and just recently it has buggered up again.
    its a limited slip diff and i bearly do skids and that and i was wondering if any body could give me any reasons why its happened this many times too the same side of my diff cause my right one is perfectly fine so yeah if some one can give any reasons it be much appreciated
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Check the breather on the diff - if it's blocked oil will be forced past seals when the oil heats up.
    04 VZ sv8
    Nov 2009
    cheers i will have a look, would i have to have the seal replaced again???
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Possibly not if it is a blocked breather - if it was repaired by a 'proper' mechanic they should have checked the breather first. Try cleaning first (if it is the breather)
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    has the axle been checked for seal runout it may be burning out the seal ? ???? is the housing straight ???
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    "bearly" doing skids is admitting to doing skids, and doing them at all is too many skids for a factory holden LSD.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    04 VZ sv8
    Nov 2009
    just took car to a mechanic who took it for a drive, he said it most likely is the bearings, he puts the fault on previous mechanic who "fixed" it, he reckons that the other guy packed it full of grease to like delay the oil leaking, booked in for tuesday to get looked at properly.
    strgas's Avatar
    Oct 2009
    04 VZ sv8
    Nov 2009
    it was done by a transmission and differential place, had seal and that fixed then couple weeks later it was leaking and he fixed it free of charge and now it buggered again a year later all on the same side, rear left
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by ryan86 View Post
    That sounds a bit sus - if the seal was replaced you must first remove the bearing and the retaining ring to actually replace the seal....it is normal practice to replace the ($11) bearing at the same time and the retaining ring.
    Packing the bearing with grease is one of the old used car salesman's tricks.
    04 VZ sv8
    Nov 2009
    had car in to the mechanic, he showed me wat was wrong, i need a new axle and every thing that goes with it, brake disc, bearings etc, he said the axel is bent and there was a something that was bent out of shape that was grinding into the disc that has left a small trench like groove in it.
    was either my fault or previous owners not too sure, we dont know why the previous guy who fixed the axel seal didnt tell me about it
  1. Quad Axel
    By markER717 in forum Car Audio
    Last Post: 30-06-2009, 02:23 PM
  2. axel stands
    By King_berald in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-05-2009, 11:56 AM
  3. movement in diff axel ?
    By vsl67 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-03-2009, 04:36 PM
  4. Axel fix
    By Patrio7 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-08-2006, 12:32 AM
  5. getting axel out of diff
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-04-2006, 06:19 PM
