Results 1 to 12 of 12
Thread: HELP!! Cranks over but Won't Start - Code 12 (no errors)
    1995 VR, 1987 VL
    May 2009
    East Gippsland, Vic
    Exclamation HELP!! Cranks over but Won't Start - Code 12 (no errors)
    Hey, I've checked out most of the "Won't Start" threads and have found no answer so far.
    I'm hoping for some advice before i go buying parts and spending a fortune.
    The case:
    My Clutch Pressure plate fingers wore out (which meant i couldn't engage my clutch) so i pulled into the garage in 1st gear (partially engaged due to the clutch) and as i was pulling in my revs dropped to say 500rpm and i just managed to pull into the garage an turn her off. I figured the rev drop was just do to the clutch being partially engaged, but after i removed the gearbox and replaced the clutch with a clutch kit, i went to start the car and she wouldn't start.
    It cranks over fine and occasionally fires, but will not start.
    Tips and tricks already tried:
    - My battery went flat because i had the radio (& 2 Amplifiers) for nearly 4 days straight, and when i charged the battery with a good quality digital battery charger, i didn't disconnect the Neg terminal (hoping i haven't wrecked my ECU)
    - CAS just replaced, still no help
    - 500Km old NGK Plugs, which are giving a good spark
    - definately getting fuel, cause plugs are wet
    - No error codes (just 12 [no faults])
    I don't get it... I've got FUEL, AIR and good SPARK but no go
    I've made her a Hold-On Commodore
    Foam Tuned 1995 VR Series II - 9psi Boost - Manual - FM Intercooler - 3" S/Steel Plumbing
    Super6 Injectors - Ceramic Wrapped Genie Extractors - 2.5" HiFlow Cat - 2.5" HiFlow Catback Exhaust with a 4" Dump Resonator
    93 VR Executive Wagon
    Mar 2009
    Melbourne, Bentleigh East
    have u checked all fuses. a little 15 or 20 amp clip fuse works to start the car. if its broken then all the car will do is crank and wont engage.
    1995 VR, 1987 VL
    May 2009
    East Gippsland, Vic
    Yeah I've had a look at the fuses. But it can't hurt to go over them all again, i'll do that tonight.
    Any other suggestions? Anyone?
    1995 VR, 1987 VL
    May 2009
    East Gippsland, Vic
    OK update -
    Went over all fuses = All fine
    White Tiger's Avatar
    White Tiger is offline Semper Fidelis
    VN Executive Wagon VR Berlina V6
    Jul 2009
    Bordertown SA
    vs calais
    Dec 2008
    cam angle sensor maybe?
    usually if youve got spark fuel and crank its the crank angle sensor so thats why im still thinking along those lines...
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    ^ Try the cas.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    1995 VR, 1987 VL
    May 2009
    East Gippsland, Vic
    Yeah, Have tried the CAS, still no help
    I'm trying a new set of spark plugs, I'll let you know how it goes
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Only thing I can add is to make sure your battery is absolutely fully charged and in good condition before you try starting....once the volts drop, the ECU does funny things.
    And you say you have good spark - how do you know?
    1995 VR, 1987 VL
    May 2009
    East Gippsland, Vic
    I was testing the simple things again, fuel, etc...
    when i noticed that although my leads would give a nice good big blue spark, almost all of the actual plugs weren't giving a very good spark (when rested against the block while the engine is being cranked over * Hako*) due to being fouled
    So Problem is SOLVED!!!!
    I installed a new set of NGK Spark plugs and she fired up straight away!!! don't i feel annoyed, it's always the simple things
    O the joy of 9 pounds of boostage under your feet again
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by JA2Z View Post
    That's the reason why I asked 'how do you know you have a good spark'.....resting it against the block is not the way to test for spark.
    TheForgotten's Avatar
    TheForgotten is offline only human......
    VR EXEC
    Dec 2005
    quarantine
    I'd be asking why your plugs are fouled after only 500km
    Quote Originally Posted by MY-42-VT
    if they didn't have that thing between there legs we'd laugh and throw rocks at them
    WTB VR/VS FACTORY HEADUNIT BRACKETS PM ME
  1. VS Ute cranks over but will not start..
    By BOGANV8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-05-2010, 04:17 PM
  2. Code errors
    By VRoooom! in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-09-2009, 12:51 PM
  3. checking code errors on VY LS1--detailed
    By Joey_21 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-11-2008, 10:50 PM
  4. code errors
    By kb6437 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-06-2008, 02:16 PM
  5. Car Cranks Wont Start
    By GROOVA75 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-04-2008, 11:46 PM
Tags for this Thread
