I did a bit of a search but couldn't really find much similar so i started a new thread if theres another can a mod merge it? Anyway my fuel gauge on my 95 VS fluctuates when i go up and down hills or accelerate from intersections or to over take it drops by up to a 1/4of a tank but goes back up after a minute or so. Is this normal in the VS? im too used to my VT with the distance till empty, but the needle bouncing around is a pain in the arse when you get low on fuel at the end of the week
Its normal as far as I know. On sedans the float is at the front of the tank, so it will read lower when going up hills and higher when coming down hills. The gauge is basically a coil of wire that expands/contracts by heat controlled by resistance of the sender unit. In other words the gauge wont give instant readings to changes.![]()
Nah I think most VS's do it. My old cluster did it, but I replaced that, new one still does it. It must just be the sensor in the tank. I'm not sure, it's no big deal really, just wait till your fuel light comes on until you start worrying.
My VS Acclaim
http://forums.justcommodores.com.au/...ml#post1199955
thanks fellas and na my name aint earl hahahaha
A quarter of a tank seems a little extreme. I am wondering if the swirlpot is damaged or has even broken off?
