Results 1 to 13 of 13
Thread: VS V6 not starting
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Default VS V6 not starting
    Car is a factory LPG car that has had LPG setup removed a few years ago. Is at 380xxx ks and I suspect it has been run dry. I put 15 litres of fuel in and had a tried to start it a couple of times. After I stopped cranking (each time) I could hear the fuel pump still running, and a loud gurgling noise from the fuel tank as the pump stops. Suspect a blockage or air bubbles in the fuel lines. Going to bleed the fuel system when I finish work tonight. Any other ideas?
    vs commodore
    Oct 2009
    Tamworth NSW
    Hi, These fuel systems should not need bleeding,They continually circulate the fuel from tank to engine and what is not used is directed strait back to the tank. Air should not be able to block it at all.The other things I'd look at are the fuel filter,could be blocked, or the fuel pressure regulator at the back of the fuel rail,it might get blocked up if it was run on gas for ages and the fuel left inside the rail evaporates and goes like varnish type stuff.someone else here will more than likely know more than me about it,but I hope this helps you out.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    If it has run dry then the pump will be stuffed. It sounds like it is working, but it can't build up any pressure. Try a different pump. I would replace the filter too.
    Visit my Facebook page
    '96 VS Commodore Equipe Sedan
    Apr 2009
    Try pulling the fuel line off at the regulator and just turning on the ignition key. You should get fuel flowing out of there. If not then as above, fuel filter may be blocked. It could also be your MAP sensor being faulty, or Crank Angle Sensor faulty. Try also checking for blown fuses...
    Is it at least attempting to fire?
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    VS....no MAP, it runs a MAF.
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    Fuel pumps in VR's and VS's are lubricated by the fuel itself, if it runs dry too many times, its rooted.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    Jan 2008
    Yeah Im not sure about the fuel pump. Though a stuffed pump+ fuel filter does make a lot of sense. Im gonna whip the hose off just before the regulator and run some fuel through to see. If not in the morning Il whip the injectors, regulator and filter off the VR and see if it helps.
    N/A
    Apr 2009
    VIC
    Check if its got any error codes. I've replaced my crank angle sensor TWICE in 2 years!! Same problem. Kept cranking over but didn't want to start.
    Apr 2009
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Okey Dokey, I shall remember that... it has been a while since I had my trusty VS
    N/A
    Apr 2009
    VIC
    Quote Originally Posted by Rossbx View Post
    Unless its been MAFless tuned..lol
    Then it will have a MAP sensor!!
    Jan 2008
    Turned out to be the immobilizer. Because the keyhead has been glued back together by a previous owner, rather than screwed, there was no contact between the key and the keyhead (you will know what I mean if you have pulled one to bits before). So now the locks need to be cycled before you can start it.
    Vs Equip
    Jul 2008
    Quote Originally Posted by VS_WPN View Post
    the vs runs a MAF not MAP
    N/A
    Apr 2009
    VIC
    Quote Originally Posted by linz View Post
    Correct! Unless you MAFless tune it then you will need to run a MAP sensor. Never mentioned it had one stock.
  1. vr not starting
    By vr stylin in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-04-2009, 11:33 PM
  2. 5L not starting
    By VNexecutive in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-02-2008, 11:59 AM
  3. Car not Starting
    By Andre's SS in forum General
    Last Post: 08-07-2006, 02:34 PM
  4. vn not starting
    By vn4play in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-11-2005, 05:30 PM
  5. vn not starting
    By mojo_type in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-06-2005, 10:51 PM
