Page 1 of 2 12 LastLast
Results 1 to 25 of 33
Thread: I stuffed up
    Kirbs's Avatar
    Kirbs is offline L plater
    96 VS Executive S2
    Mar 2009
    Default I stuffed up
    Well I was going to change my front springs today, But I kind of stuffed up very major, I pulled nearly every joint/connection out, then my brother knocked the box over that I had all the bolts in sets so now I don't have a clue what bolt goes where. Can someone take some photos of theres or let me know what bolts go where? Would be much appreciated. Also, When I was trying to change the spring but I couldn't get the bolt on the top undone, Any tips on how to get it undone? Really beginning to piss me off now haha.
    Quote Originally Posted by levymetal View Post
    what a coincidence! the only way i can get my 2 year old son to sleep is if he's in the front seat of the car, no child seat, no seatbelt, and i'm doing 250km/h down the mornington peninsula freeway.
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    bolts are pretty self explanitary put them into groups then divide them into pairs. so each pair one goes on one side and the other on the other. they are all different apart from their pairs for each side. u will work it out. the best way is to rattle gun that nut
    Kirbs's Avatar
    96 VS Executive S2
    Mar 2009
    Aww I don't have a bloody rattle gun haha, Told dad we should get one but he wasn't to interested haha.
    vr
    Jun 2009
    make sure you have a set of spring compressors on those front springs before you even atempt to take the nuts off
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    It is easier to undo the top nut with the car still on the ground. It should be the first that is cracked.
    With all the other bolts, they can only go where they fit. But you should only have 2 bolts that hold the strut to the stub axle, 1 nut that holds the swaybar link pin to the strut, sometimes you need to remove a caliper bolt to get one of the strut to stub axle bolts out.
    Visit my Facebook page
    Kirbs's Avatar
    96 VS Executive S2
    Mar 2009
    Wow, The caliper bolts are so rusted on I cannot get the bastards off, and the caliper bolt is stoping me from pulling the lower strut bolt out.
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    ......Big Bar
    Gas, Ass or Grass nobody rides for free
    Quote Originally Posted by vsv8berlinawag View Post
    You tell him (coz you are right)
    Kirbs's Avatar
    96 VS Executive S2
    Mar 2009
    Yeah, I used an 80cm piece of steel pipe, that got it right off.still having trouble putting it all back together though, Like a very hard jigsaw puzzle.
    ScoHar's Avatar
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    what do you need help with, as said above it should be pretty self explanatory, ill try make it easier, 4 big long bolts and nuts for strut-hub, about 12 smaller nuts for top hat, one flat looking gold coloured nut for under the bearing, and one for above. let me know exactly what your stuck with, done it a few times now.
    Kirbs's Avatar
    96 VS Executive S2
    Mar 2009
    Well there that bar a the bottom of the strut that connects to the car that the brake calipers and all that are attatched to, I undid that where it actually joins the car, So now I'm having trouble manouvering that and that S shape bar back into place, The S shape bar attatches to the car just under the swaybar (i think). Once I manage to get them back in I should be all good to fix up the rest, I need to bleed my brakes now aswell because my mate took the bolt off that holds the hose to the caliper.
    vs commodore
    Oct 2009
    Tamworth NSW
    Hi,a gregorys manual would be helpful for these kind of jobs,I never do anything major without it.Step by step,you cant go wrong,unless you are a complete dill.
    Kirbs's Avatar
    96 VS Executive S2
    Mar 2009
    How much do they cost? Well I have everything back in except for the little bar that connects the swaybar to the strut, It's a tad tricky, How do I get it back in, And in what order to the bushes/washers go?
    ScoHar's Avatar
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    it goes, top down, bolt-washer-rubber-sway bar- rubber-washer
    Kirbs's Avatar
    96 VS Executive S2
    Mar 2009
    Well I need a new bar because I bent mine and stripped the threads. Where can I get one and how much?
  15. #15
    A bicycle
    Aug 2009
    Gippsland, Victoria
    do you mean the swaybar link bar thing, runs vertical? ebay will have what you're after probably.
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Quote Originally Posted by NonStick Squid View Post
    @old mate you drive a vs ute therefore you're a bogan therefore your point is invalid
  16. #16
    Set of thongs
    Dec 2005
    Stonedville
  17. #17
    Kirbs's Avatar
    96 VS Executive S2
    Mar 2009
    I'm in W.A, Im heading down to auto one to get a pair of heavy duty ones with bushes/washers/nuts now.
  18. #18
    Kirbs's Avatar
    96 VS Executive S2
    Mar 2009
    Now have a nothalane Heavy duty kit, New everything. Sweet.
  19. #19
    Set of thongs
    Dec 2005
    Stonedville
  20. #20
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    You certainly did it the hard way...
  21. #21
    Kirbs's Avatar
    96 VS Executive S2
    Mar 2009
    How do I put the swaybar link pins in? Wish I never touched the ****ing thing now.
  22. #22
    Kirbs's Avatar
    96 VS Executive S2
    Mar 2009
    Are you being serious? Please get out of my thread unless you have something to contribute. Cheers
  23. #23
    Kirbs's Avatar
    96 VS Executive S2
    Mar 2009
    Ok man thanks for your input. Anyone else have any ideas how to install them? I'm happy to rip everything off the car aslong as I can get this finished.
  24. #24
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    You have to have both sides undone at the same time. Put the pins in with the inner bushes on first, then put the outer bushes and nuts on.
  25. #25
    Kirbs's Avatar
    96 VS Executive S2
    Mar 2009
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Awww shit, Sounds so ****ing obvious now haha. Well I'l wait for my mate to come around with his jack then we'll get it done. Thanks mate.
    Oh yeah, I saw you the other day at the post office near the war memorial, was gonna say gday but you were to far away haha.
  1. Something stuffed?
    By DANNY8 in forum The LAN Lounge
    Last Post: 14-08-2008, 10:52 AM
  2. Its got me stuffed??
    By Rookie 4.6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-02-2008, 12:50 AM
  3. Ever been stuffed around over the net?
    By Kikki in forum The Pub
    Last Post: 10-01-2008, 09:09 PM
  4. help key is stuffed
    By ace_bowler2000 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-03-2007, 05:20 PM
  5. vl has stuffed up again
    By muffman001 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-09-2005, 09:47 AM
