Results 1 to 6 of 6
Thread: keybarrell problems URGENT HELP NEEDED
    vr executive shitbox
    Nov 2009
    Smile keybarrell problems URGENT HELP NEEDED
    hey jst bought a vr commo and the guy lost all the keys so its got
    busted arse barrel and no steering lock how do i bypass the bcm so it thinks its got the key
    in the ignigtin .... any help greatly appreciated. dnt fill my thread with studip arse comments
    ps. the car is not stolen i revs checked it
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Turn the ignition on (all reds on) and leave it like this for an hour - this bypasses the immobiliser. You can then start the car but need to replace this procedure if you turn it off.
    VS l67 statesman
    Dec 2008
    this thread will probaly get locked like most other ones likes this
    But is this car a everyday Driver or something you just want to move ?
    I ask because you are going to have to get a new key from Holden and key barrel evently so you have to provide them with a chassis number and proof of ownership
    also I can see you are very fond of your VR excutive shitbox
    vs clubsport
    Mar 2009
    brisbane
    If you can get a vn computer just plug it in and off you go as it does not look for the signal from the bcm
    Float like an elephant sting like a tree clubsport hits what doug does'nt see
    Nov 2009
    thx for the waste of time vn computer has different pugs found out the hard way ....
    any more ideas
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Read my post #2 again - that's the factory method and is mentioned if the owners handbook. I'm guessing the key barrel is removed and if so you will be able to rotate the actual ignition switch....if you can get reds and leave it for an hour the engine will crank with fuel and ignition.
  1. Problems with alarm (Urgent help needed!!)
    By Vg-ute-mad in forum Electrical Wiring / Questions
    Last Post: 11-11-2010, 11:50 AM
  2. Urgent Help needed - LS1 Auto Problems
    By buggzy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-08-2008, 10:25 PM
  3. urgent help needed
    By back_in_a_vr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-03-2007, 05:42 PM
  4. urgent help needed - idle problems
    By vnbelina in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-07-2006, 04:57 PM
  5. URGENT help needed please!
    By newo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-12-2005, 02:31 PM
