hey guys.
i was just wondering what camber kit i should put in my vs?
its a vs acclaim with Superlows in the front and ultras in the rear running ve ss 18 x 8's
which woudl the best camber kit to run. inner? outer? or inner and outer?
let us know with your opinion.
thanks
go both inner and outer as this will give the most adjustment when using ultra lows
I got a Vp sedan and i got the kmac stage 2 adjustable tops which allow up to 5 degrees of camber and plus adjustable caster. They do the same item for the vs. I have found them to be a really good item. They will cost you about 300 to 350. Worth every cent
Yeah i kinda relised after i posted it. Hahaha
Whiteline 4pt Camber Kit, $179.
- GSL RallySport - Ph: 1300 884 836 -
Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
- QFM Performance Brake Pads -
Also specialising in
- DMS High Performance Shock Absorbers - Monit Rally Computers -
