Results 1 to 3 of 3
Thread: Changing the rocker cover gasket
    Kirbs's Avatar
    Kirbs is offline L plater
    96 VS Executive S2
    Mar 2009
    Default Changing the rocker cover gasket
    My mate got a defect for rocker cover gasket leaking, Picky cops haha. Anyway this is pretty straight forward aye? Remove everything in the way **** a new gasket then do it back up? Has anyone got a guide or something? Cheers
    Quote Originally Posted by levymetal View Post
    what a coincidence! the only way i can get my 2 year old son to sleep is if he's in the front seat of the car, no child seat, no seatbelt, and i'm doing 250km/h down the mornington peninsula freeway.
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    what makes it easier is if he puts a few small dabs in cover then sit the gasket into it. just enough to hold the seal while he is lining it up with the bolts
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Drivers side the alternator has to be loosened, passenger side the throttle body has to come off, undo the 3/8 bolts...
    Dont over torque the bolts back down, they dont need to be rediculously tight. And as above, put some vaseline inside the channel where the gasket sits. Just make sure you dry any cleaning solvents off before you put the new gasket in otherwise it will stretch.
  1. Replies: 15
    Last Post: 13-04-2009, 05:31 PM
  2. VX Super Charged Rocker Cover Gasket
    By SSV8pilot in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-10-2006, 03:11 PM
  3. VS V6 Rocker Cover Gasket Leak.
    By Fitzy3VSVY in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-07-2006, 01:44 PM
  4. rocker cover gasket
    By jim898 in forum V8 Development and Modification
    Last Post: 10-01-2006, 12:36 AM
  5. VK - Changing rocker cover gasket
    By Shifty1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-12-2005, 10:38 PM
