Results 1 to 17 of 17
Thread: changing hubs
    98 vt s pac
    Feb 2009
    Corowa NSW
    Default changing hubs
    ok im gunna have a crack at this next week just wondering how hard it is top change my front hub on my 95 vs exec it has abs apparently that makes a difference? from what ive read on here theres only 3 alan key bolts to undo after i take the caliper and rotors off right?
    VS l67 statesman
    Dec 2008
    The allan head bolts are locktited in and can be a bitch to get out ,you can buy a allan head drive that attaches to a ratchet that makes the jobs easier & pretty much you said above is what you do but you will have better acess if you remove the bottom two shock bolt and swing it out of the road
    As for the hub if you get the wrong one the brakes will feel hard and shudder and lock that hub up volently So Make sure you get a ABS HUB but the IRS or Standard diff is what makes the difference so double check
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I just used an allen key with a length of pipe on the end for leverage - use same method when replacing.
    I only lifted the caliper out of the way , removed the disc and then could access the 3 bolts by turning the steering wheel.
    As vsl67 says, you must get the correct hub - left is different from right hand plus the hubs are different for solid and IRS. If you don't have ABS then just make sure you get the correct side.
    98 vt s pac
    Feb 2009
    Corowa NSW
    pretty sure its not IRS its too low to look under but i had it jacked up the other day and could kinda see under there.
    VSII Calais supercharged
    Mar 2005
    South Coast, NSW
    You definitely don't have IRS. VS executive models all had live axle.
    Car theives should be treated just like horse theives and cattle rustlers in the days of the wild west... Hang them!
    Don't be stupid. Power isn't measured by the size of your tacho
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by mynameisearl View Post
    Double check what rear-end you have and if you have ABS...........it's a long walk sometimes.
    Mar 2005
    South Coast, NSW
    I should have also mentioned that the series 1 VS exec did not come with ABS. No IRS, no ABS, not even an airbag.
    98 vt s pac
    Feb 2009
    Corowa NSW
    Mar 2005
    South Coast, NSW
    We're talking about a 95 VS executive right? What makes you say it has ABS? ABS was only available on the VS Acclaim model and upwards.
    98 vt s pac
    Feb 2009
    Corowa NSW
    Quote Originally Posted by Scooter79 View Post
    im just going off what i see there is the ABS anti lock braking badge thing below the head unit and the ABS light on the dash lights?
    Mar 2005
    South Coast, NSW
    The ABS light on the dash doesn't necessarily mean ABS is hooked up or installed and the ABS logo on the stereo surround is just a sticker that could have been peeled off a car at a wreckers or the stereo surround could have been replaced at any time with one from an acclaim.
    The simplest and quickest way to check if you have ABS is to pop the bonnet and look for the ABS module. It's a black and silver box located on the drivers side between the engine cover coolant overflow bottle and has a bunch of very thin metal hoses attached to it.
    I've attached a pic to show you what I mean. If you don't have the module, you don't have ABS.
    98 vt s pac
    Feb 2009
    Corowa NSW
    yep thats there
    VS Berlina 3.8
    Dec 2008
    Pretty sure it could be optioned on though. Pov pack standard had none of it.
    VY Berlina V6 / R31 Skyline
    Dec 2008
    Sorry mate i think your wrong here
    I have a VS Exec with:
    Dual front airbags
    ABS Brakes
    IRS
    Metallic Paint
    FE2 Suspension
    All from factory, on an exec.
  15. #15
    98 vt s pac
    Feb 2009
    Corowa NSW
  16. #16
    Mar 2005
    South Coast, NSW
    Well, bugger me sideways
  17. #17
    Kurtp's Avatar
    Kurtp is offline VR Buicks > You ;)
    VR Series 2 V6 Sedan
    Aug 2009
    Pakkey VIC
    Wasn't IRS and ABS optional, not stock?
  1. VY Hubs to Vs
    By statement in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-10-2009, 09:28 PM
  2. ABS Hubs
    By VR38 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-05-2009, 05:03 PM
  3. vt hubs on vs
    By Disturbed_vegeta in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-05-2008, 10:19 PM
  4. VS Hubs
    By DaPlaya in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-05-2006, 08:43 AM
  5. VS Hubs
    By RAMJET in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-07-2005, 10:56 PM
