Results 1 to 14 of 14
Thread: ecotec valley sucking air throw pcv?
    vs executive
    Nov 2009
    Default ecotec valley sucking air throw pcv?
    hi everyone shouldnt it be blowing air out the valley ie crank case blow by? cheers chris
    vs commodore
    Oct 2009
    Tamworth NSW
    crankcase blow by happens when compression escapes down past the pistons and rings and goes into the crankcase.Usually a worn engine does it
    vs executive
    Nov 2009
    yer i no that but whot im arksing is it right for it to be sucking not blowing?
    vs commodore
    Oct 2009
    Tamworth NSW
    The pcv valve, or positive crankcase ventilation valve scavenges any blow by and recycles it in the combustion process.It gets sucked into the engine with the petrol and air.It creates a slight vacuum in the crankcase which will cause it to suck.The pcv valve in the ecotec(vs)is inside the inlet manifold.years ago before pollution gear was introduced,the crankcase was vented to the atmosphere,on a worn engine you could see smoke and fumes puffing out of the breather,not good for the enviroment,so they came up with the recycle idea.So Id say it should have suction.
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Chris, how do you know this is happening ? did you run the engine with the plenum lid off ?
    vs executive
    Nov 2009
    so it should be sucking? no didnt take plenum lid of im talking bout the pipe that goes betwen the inlet manifold under the plenum to the throttle body cheers
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    your refering to the filtered air pipe which should have a small amount of vacum as this where the air enters the engine and then gets drawn thru the PCV and back into the engine
    vs executive
    Nov 2009
    chrisdoesitbetter's Avatar
    chrisdoesitbetter is offline | → ³8°º™ ← |
    VR 3.8L
    May 2009
    quick question, if you were to take out the pcv valve and leave the cover off and start the engine what would happen? has anyone done this. i did it today to see if i could feel and blow-by and the engine just revved very high
    vs executive
    Nov 2009
    Quote Originally Posted by chrisdoesitbetter View Post
    whot do ya mean by cover? engine cover thats says ecotec on it or plenum lid or rocker cover? im gessing ur talking about plenum lid yer it would probly rev off its head or somting wierd if i even started lol y are you arsking about it if your already done it ? just take the oil filler cap off and putt ur hand over the hole and fell the amont thats coming out my engine witch is pretty tired and theres no blow bye im guess thats probly cos i got the pvc connected il check that out tomoro
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    with the amount of pollution gear on them nowdays you cant even judge blowby with the cap off it all gets sucked out so fast thats where most people go wrong looking at cars they think its in great condition due to no vapours coming out the lid LOL
    vs commodore
    Oct 2009
    Tamworth NSW
    Yeah,engine managment was a lifesaver though,just compare a vl engine bay to a vn,the vl has about a million miles of hose,most of it pollution gear
    vs executive
    Nov 2009
    sorry to every one thats posted in this thread was in a bit of a hurry yestorday and didnt realies the pcv is inside the plenum lol as i thort the filted air pipe wos the pcv i pulld the plenum lid off this moring and seen the pcv isee how it all works now cheer everyone
    VR 3.8L
    May 2009
    Quote Originally Posted by chris89 View Post
    under bung behind the thermostat housing... revved as if it was WOT...guess it must have fed all the air from there to the throttle body??
  1. Throw out bearing
    By DavoVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-02-2010, 06:09 PM
  2. vy ss throw overs!!
    By hypo83 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-10-2009, 02:24 AM
  3. Throw Out Bearing, I Think
    By vt s in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-05-2009, 07:09 PM
  4. Throw out
    Last Post: 25-04-2009, 10:43 AM
  5. Pulled heater controls out - now a strange sucking noise/sucking from pipes?
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-01-2008, 04:01 PM
Tags for this Thread
