Results 1 to 14 of 14
Thread: Home made cold air intake
    VS SS V8 Ute
    Nov 2009
    WA
    Default Home made cold air intake
    before i start ill just say that this only cost me $20 and bout 10 mins
    ok so it was a really hot day and was thinking, there must be a cheaper way for a cold air intake rather than spending the odd $200 on some plastic moulding intake kit. So after i had read some ideas on home made intakes i decided to rig one up myself.
    for this mod i kept the standard air box and KN panel filter.
    All thats needed:
    -an old radiator hose (i picked up a $20 S-shaped hose from super cheao auto, but made sure it would be long enough)
    -tin snip (or the rite sized hole saw)
    -and a metal coat hanger.
    -drill/drill bit
    so all i did was cut a hole in the side of my air box a bit smaller the diameter of the hose (so it would be an air tight fit)
    and then i cut another section out of the splash gaurd where the other end of the hose sits and drilled some holes to fix the coat hanger inplace to support the hose up. give the hose i good yonk to see if would stay in place, so i had no need to fix anything down.
    and that was it, drove round after that and my temp gauge was quiet lower than it was before hand.
    i might try and find a fitting to go on the end so it looks prettyer, kinda like an exhaust tip but obviously in sumting lighter and bit smaller, but u get the idea.
    TheForgotten's Avatar
    TheForgotten is offline only human......
    VR EXEC
    Dec 2005
    quarantine
    looks like a great idea to me, but i can't see that little pipe flowing enough cold air to make a difference. it simply wouldn't overcome the hot air coming in the standard intake hole
    Quote Originally Posted by MY-42-VT
    if they didn't have that thing between there legs we'd laugh and throw rocks at them
    WTB VR/VS FACTORY HEADUNIT BRACKETS PM ME
    VS SS V8 Ute
    Nov 2009
    WA
    thats why i suggest fitting a wide mouh at the end, then the air is just forced, besides im running to intakes now, i have noticed the diff tho
    VS executive
    Jun 2009
    i hate too sound like a prick but the splash guard is called the splash guard for a reason.... youre probably going too have water problems.
    VS SS V8 Ute
    Nov 2009
    WA
    Quote Originally Posted by pillzor View Post
    how would water run upwards through an s pipe into a air box then rise high enough through the filter and then up the intake pipe into the engine. 4wds dont seem to have problems with rain going into there snorkel, and besides i dont uasually drive through water that deep.
    VS executive
    Jun 2009
    i wouldnt think its likely when you put it like that i was just saying why mount it where theres an obvious chance of water getting into it being that holden put a splash guard there obviously because water splashing up could be a problem.
    why take the risk?
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    I cant see water being a problem. I doubt water will even make it up that far, and if it does it probably wont even touch the air filter, but if it does the filter would turn it into a mist, which like water injection it will bump up compression a poofteenth and lower intake temp. The end result it gets turned to steam and you also have a slightly cleaner engine . It wouldnt have time to corrode components. If the hose somehow became submerged in water the air would be drawn through the standard inlet and probably wouldnt have enough vacuum to draw water up the hose.
    I dont have a problem driving in the rain with my VS S/C factory OTR CAI. You only have to worry when you get a mass of water in the intake and bend rods (which Ive seen cases where its happened).
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    VS executive
    Jun 2009
    Quote Originally Posted by azzfox View Post
    why would you have any problems with water with a super 6 cai? , the whole thing with water in getting in cai`s has to do with the pvc piping type ones that people like too mount behind fog light holes or generally closer too the ground,
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    wow... That little intake is one way to starve a motor of air...
    *sigh*
    Go all the way, Or don't even go there at all...
    What you have made is nothing more than trying to breath through a straw if you are under water......
    MaT
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Because its exposed to anything oncoming - dirt, bugs, water and rain splashing off the grill.
    Still low chance of water making its way up a low-mount CAI and if it does it will only be in small amounts making it little threat. But youre not wrong, worst case scenario it can do damage. But try to avoid driving into lakes
    lol @ hozy's post
    My (ex)Ride
    VS SS V8 Ute
    Nov 2009
    WA
    hmm well it seems people are agreeing and dissagreeing on this under car intake. i think ill have another look in my engine bay to remount the intake pipe. there is a channel it can sit on, i think it has one of the heater hoses running along it to front of the bumper than bak round again, not as much of wind path but probably safer away from water. but can anyone please enlighten me on how this CIA will be long enough to join into my air box?
    COMMODORE COLD AIR INTAKE for VN VP VQ VR VS V8 GM NOS - eBay, Air Intake, Fuel Delivery, Car Parts, Accessories, Cars, Bikes, Boats. (end time 15-Nov-09 09:55:28 AEDST)
    MX83
    Jul 2008
    hills area, sydney
    It sits on top of the radiator/fan shroud, hence OTR (over the radiator) CAI. Sit it in place, the second bit of plastic connects up to go down to the airbox and you either have to buy the proper bottom section of the box from holden, or just cut a bit out so it fits in.
    JCCC NSW
    Quote Originally Posted by Troy711 View Post
    My mum dropped me off at work one day and she was doing 90 in a 60 zone. When I pointed this out to her she said 'shut up, if you don't like my driving you can get out and walk'.
    VS Executive S2
    Nov 2009
    Perth, Western Australia
    chrisdoesitbetter's Avatar
    chrisdoesitbetter is offline | → ³8°º™ ← |
    VR 3.8L
    May 2009
    put a bit of flyscreen over the end of the intake hose (under the car) so if you are sitting behind a truck you car wont swallow rocks and cow dung.... as long as your happy with it thats all that matters!!
  1. Home made cai
    By SKNOT9 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-01-2008, 04:10 PM
  2. Building A Custom Made Cold Air Intake From FibreGlass Or Metal
    By Vn_666 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-11-2006, 08:37 AM
  3. Home Made Cold Air Intake..
    By SiC-MeTaBoLiC in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 16-12-2005, 02:17 PM
  4. Home Made intake
    By Phantom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-01-2005, 06:41 PM
  5. Home Made Cold Air Intake
    By hrtdyke in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-11-2004, 08:43 AM
