Results 1 to 3 of 3
Thread: Whats causing the scratching on my side windows?
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    Default Whats causing the scratching on my side windows?
    as the title says, my side windows on the ute always seem to get scratched up in one spot when the window is wound up and down, leaving big vertical gouges. I've got a feeling a something is missing that guides the window. Any ideas?
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    My mate had a similar issue with his monaro. He found that some small sand got into the outer seal that's against the glass and was scratching the glass.
    He pulled off the seal, cleaned it and was sweet.
    That's one possibility...
    Good luck with it mate!
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    when u get back to perth i will chuck sum glass at ya
  1. [SA] Vn / Vp Set of Tinted side windows For sale
    By LightningVP in forum Parts And Other Items For Sale
    Last Post: 12-02-2009, 07:08 PM
  2. rear power windows making scratching noise?
    By axemurderer101 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-12-2007, 09:01 PM
  3. Whats causing the beeping!!?
    By PsYko in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-11-2007, 01:12 AM
  4. power windows on one side not working?
    By gazzabrizz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-08-2006, 02:34 PM
  5. Installing side windows??
    By Juaz87 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-09-2005, 10:44 AM
