Results 1 to 5 of 5
Thread: Fuel in the oil
    vr v6 wagon
    Nov 2009
    Default Fuel in the oil
    Had problem a few months ago with black smoke on starting hot or cold. Replaced pressure reg valve and ok for a while but problem returned recently plus now have rising oil level. oil smells of petrol. Any suggestions?
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    check carbon canister lines for fuel ... is the car on gas ??? fuel tank venting via carbon canister ????
    vr v6 wagon
    Nov 2009
    strgas's Avatar
    Oct 2009
    Thats correct it stores fuel vapour from the tank and allows the fuel tank to breathe without venting fuel to the atmosphere . if the hoses are blocked or kinked it could then force fuel thru the vent lines into the engine
    vs commodore
    Oct 2009
    Tamworth NSW
    I know a guy who had a leaking injector,and had the same thing happen to his oil,could be worth checking, it would have to get past the piston and rings to get to the oil.I suppose it could get squeezed past on startup,but Id have thought it would cause the motor to not turn,same as when a head gasket blows and you get water into the cylinders,It cant squeeze liquid like it can air and locks up.Has your motor been hard to wind over at all?
  1. blockage in fuel line - appears to be fuel pressure regulator??
    By ryan1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-08-2011, 06:23 PM
  2. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
  3. Fuel gauge stuffed? or engine just drinking fuel?
    By Noy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-12-2007, 05:51 PM
  4. fuel surge turning right? weird inst fuel readings
    By vkotis in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2006, 12:00 PM
  5. fuel injected 5ltr motor setup for dual fuel
    By ma77es in forum Swap / Wanted to Buy / Trade
    Last Post: 28-05-2006, 07:03 PM
