Hi,
I have a Commo VS Executive (V6) and having a problem where my car is randomly cutting out on me. Some times after the car cuts out I can start it, but some times it won't start for a random length of time..
When I can't start it, it is cranking over but there is no spark at the coil pack.
I have changed:
ECU (tried 3)
Crank angle sensor
DFI (coil pack)
The lume
Cam angle sensor
Fuel pump
Despite changing these things, the problem is still occuring and was wondering if anyone has any ideas of what could be causing this problem?
wow deja vu. Exactly whats happening to me. Let me know how you go with it thanks
Sure... Did you end up fixing your problem?
nah mate, ive documented everything ive done in this thread:
For the mechanically minded. HELP BEFORE I BURN IT DOWN!
Does the car cut out or surge drmatically when turning corners etc. I had a VS V6 auto commodore that used to surge and cut out all the time. At first we thought it was the fuel system so we replaced all the injectors, rails, pump and everything only to still have the problem. After a lot of yelling, swearing and hair pulling we fould it to be a faulty coil pack. Check each one and if need be $90 from Coventries will hopefully fix it straight away.
Hope this helps you.
Nah, it just cuts out randomly. Its really strange and frustrating.
As I stated in another thread, I have been having the same problem, replaced a tonne of crap and I think I have finally nailed it down to it being the immobiliser. I have my car booked in next week to have the BCM replaced.
This car is an execute model, so there is no immobilizer, but I've changed my BCM and the problem still occurs.
Do you have a red light in the centre console? Yes? It's to tell you when the immobiliser is active.
Yeah, there is a red LED that flashes, but isn't there suppose to be like an RFID key that tells the immobilizer receiver that its OK for the car to switch on?
Don't thinnk the amount of buttons has much to do with it. When you put the key in, the edges of the key make contact with two pieces of metal around the ignition barrel. That contact is what tells the BCM that the key is in the ignition.
This is a good chance to make sure the two pieces of metal are making good contact with the keyhead.
Anyway, I'm retty sure all VS's had it. I don't think the imobiliser key in the pillar has been in use since VP's.
Mate I had a commodore do similar things,It would cut out,and not start,then it would go,we ended up tracking it to a broken wire at the rear of the car where the fuel pump goes into the tank,the wires were all shabby and one had broken,but not right through, and was loosing contact now and then.Rejoined and never happened again.It could be worth a look.But if theres definitely no spark ,this wont help much.
check the fuel pressure reg, check the wires at the bottom of the relays and next time it happens when it cranks but wont start pull off the fuel line and see if its getting fuel.
i had a similar problem with my vs v8 bt1 it was a purple wire which is ur signal wire for the fuel pump in the driver side kick panel if u got a aftermarket alarm it may need to be re soldered to some green wire with my alarm it took en a whole week for my mechanic to find it
Mate sorry I cant help but to let you know i had the sameproblem on another car of mine. Had it in Holden service so manytimes it was not funny. They could not find the problem and i ended up wholesaleing the car as i did not want to pass this problem onto anyone.
1996 VS S Ute -5 Speed ManualExtractors and sports exhaust systemVY CV8 R 18 Inch Wheels, Stage 4 Memcal Chip3.89 Diff, Lowered, CAI
has it got an aftermarket alarm?
Coolant temp. sensor.
My commodore would cut out randomly, well not cut out but it was feel as though it was gonna stall / backfire when i would accelerate. It would also piss out black smoke when it would randomly do this. So each time it happened, i would have to switch it off and then restart it, but sometimes it wouldn't start because i would of flooded it so would have to wait 5 or so mins.
Maybe this is your problem ?
disable the security system there might be a key hole in the passenger side front door jam you need the little key for it. then see if that fixes it.
I get this problem sometimes when i go around a corner or a roundabout when i have around a 1/4 tank.
