title its meant to say do buick rocker covers fit on the ecotec just wondering if they fit cos the passinger side rocker cover on the buick has a breather pipe on it and witch would help make a catch can set up .i no i could just tap a thread in to the ecotec rocker covers but yer just arsking cheers
the passenger side rocker on the buick also has the oil filler too doesn't it?
Then you would have twice the fun :P
yes, vn s1-vr rocker covers will all fit the ecotec. (iblown has a set of s1 rockers on his ecotec, with the hole welded up. i know, coz i sold them to him)
they wont fit the l67 supercharged ecotec though.
dont forget to get vn s1 gaskets aswell, because theyre different to s2 onwards.
Oh yeah VN S1 are metal yeah? they would look mint polished.
you can just use a blank grommet in the breather hole for the early rocker covers and poilish em up and they look mint.
the later VN-VR are the same as the ecotec ones. they just altered which head they put oil filler on. if you have a look at some ecotec covers you will see the drivers side cover even has the little tabs same as the VN-VR ones to mount the spark plug leads (on the passanger side)
Body by Holden, Soul by Brock
the Legend will live forever
I have a polished set of VN S1 covers on my VS, look sweet as.
I suggest using the VN S1 style gaskets because they seems to provide a better seal, and are easier to seat than the later ones
Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
thanks for the info peoples![]()
you can easily tell the difference, cause S1 are metal and the S2 are plastic (i believe??) tapping them together the clearly make a metallic clang. and only S1 covers will have the hole for the oil breather thingo on the passenger side.
What you do is you paint strip them thoroughly, sand them back flat (casting dags) then machine polish
