Results 1 to 2 of 2
Thread: cooling and fuel
    -ToM-'s Avatar
    -ToM- is offline Bow Down to the Emperor!
    VR Exec [EMPIR3]
    Jan 2008
    SA
    Default cooling and fuel
    Just a couple q's guys.
    Is it worth upgrading the radiator to a triple core unit?
    Is it worth replacing the thermostat with something aftermarket?
    whats the ballpark figure?
    How much should it cost to run a new set of fuel lines? Is there something you can use thats better then standard, but not outrageously more expensive?
    thanks guys
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    My opinion only, but I'd fit a 3 row radiator only if I were towing a decent caravan and needed that extra cooling capacity - otherwise the standard unit performs good. However, if you want a better margin of safety re cooling, a 3 core is the way to go along with new hoses/clamps/coolant and heater tap.
    Unless you current thermostat is playing up and/or you wish to fit a thermostat that opens earlier, there shouldn't be a need to change....plus you probably already have an aftermarket thermostat installed as the car is 15 years old.
    Fuel lines in Commodores are sized more than adequate - the V6 runs the same lines as the V8 - the only time you would need better flowing fuel lines is if you are using more fuel.
  1. vt help cooling
    By Niper in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-07-2009, 01:45 AM
  2. VS Cooling
    By Jordan88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-07-2009, 03:12 PM
  3. Oil Cooling?
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-12-2006, 01:31 AM
  4. VS air con not cooling.
    By shmity in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-12-2005, 07:46 AM
  5. Amp Cooling
    By VY2ENJOY in forum Car Audio
    Last Post: 22-10-2005, 12:54 AM
