Results 1 to 9 of 9
Thread: vs turbo max boost
    Vy ss Series 2
    Dec 2008
    Launceston, Tas
    Default vs turbo max boost
    Hi my bro has a vs v6 turbo ute that apparently has a vx engine in it. its running 5 pound boost at the moment. the engine is completely standard inside. whats the max boost in your opinion you can go to without re-building the engine?
    Vr Executive 3.8
    Dec 2008
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    some guy ran 22 and managed 2 runs before the engine died
    The Black Beauty
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    9PSI is relatively safe with stock internals. I wouldnt go higher than this.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    depends what hes done for fuel supply really as the maf will be maxing out at 4000rpm at about 8psi
    04 WRX
    Jan 2006
    beenleigh
    physically the engine will take over 15psi but need the fuel system and tune to be good enough. 10psi with a good tune will be reliable as long as its driven reasonably. My car has had 10psi in it for 3-4 years broken diffs, gearboxes, clutches driveshafts but still on original engine.
    vs commodore
    Sep 2010
    wyongah,nsw
    i wouldnt go above 6psi if u wont decent engine life and are wanting to give it a bit of stick every now and then
    VS SS
    Nov 2010
    sydney
    i used to have a VP and use to run 7psi on a standard motor, never had a drama, 9 starts to get risky
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    I ran 10PSI for five years without any problems!
  1. vx turbo timer & boost gauge
    By superCalais in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-04-2009, 10:57 PM
  2. On-Boost
    By QWiK747 in forum General
    Last Post: 06-10-2008, 09:57 PM
  3. need some boost
    By Mr_Calais in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-03-2008, 08:42 PM
  4. Boost
    By wagonb0y in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-10-2006, 09:57 PM
  5. Best turbo for low RPM boost on VT
    By Bloodmoon in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-12-2005, 01:16 PM
