Results 1 to 15 of 15
Thread: ABS light
    VZ Calais
    Aug 2005
    Mackay Qld
    Default ABS light
    This is strange....why does my ABS light come on when i hit 80k's?
    When the ignit is turned off, it goes out. After restarting it is still off.....until i hit 80k's.
    Any ideas?
    HoldrodeoLT's Avatar
    HoldrodeoLT is offline I have no lemon pledge...
    2004 Holden Rodeo RA LT, 2008 Polaris Hawkeye 300
    Aug 2008
    you need to get the code it's lodging.. then go from there.. sounds like it could be a speed sensor.
    ABS Error Codes
    About as handy as tits on a bull
    VZ Calais
    Aug 2005
    Mackay Qld
    Aug 2008
    No worries, make sure you get back to us with the problem/fix... to help the next person with the same fault. cheers
    VZ Calais
    Aug 2005
    Mackay Qld
    I was actually going to cheat.
    I know a bloke that is a Holden mechanic, i'm going to ask him if he can plug it in to the diagnostic machine.
    Aug 2008
    lol well thats even easier haha..goodluck
    VS SS V8
    Oct 2009
    Townsville, Qld
    I've got the exact same problem.... apparently caused by speed sensor frequency error... one of the hubs is throwing junk data ~80kms/hr... I asked a mechanic friend about it and got told it'll be one of the hubs! Which hub??? Your guess is a good as mine! Let me know if u get any further info plz
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    It could be the connectors - the ones at each hub. They can get knocked out of position or corrode if not filly pushed in. Also check the main connector to the ABS unit in the engine compartment which can have corroded terminals if water gets into the connnector.
    VP Exec
    Jun 2005
    As part of a visual inspection of the sensors also look for damage to (all of) the "teeth" of the rotating part (tone wheel).
    The gap between the sensor and the tone wheel is also important but probably covered by checking that the sensor is pushed into the bracket. There are shims used to adjust the air gap though and it should be 0.3-1.3mm.
    The sensors are wire coils around a permanent magnet so checking for one of the sensors with an open circuit or different resistance to the others can ID a failed sensor. For VP/VQ and VR they should be 600-1600 Ohms. VS will likely be the same.
    The sensors generate an AC voltage so a DMM capable of measuring frequency across the (disconnected) sensor wires with the car moving can also ID a dead sensor (but will probably miss one where only one or two of the voltage cycles are missing occasionally => 'scope for those). Calc. the expected frequency using the number of tone wheel teeth, tyre circumference and the road speed.
    VZ Calais
    Aug 2005
    Mackay Qld
    Quote Originally Posted by VSPantha View Post
    Yep.....error code 28.
    I'm going to have to contact my little mechanic m8 to sort this.
    Thanks for the input guys.
    VS Acclaim V6 5spd
    Jan 2010
    Quote Originally Posted by coolngroovy View Post
    Hey, Did you find a solution this? I'm having the same problem.
    VZ Calais
    Aug 2005
    Mackay Qld
    No. It lasted about 4 weeks then went away.
    It hasn't come back on in months.
    VS SS V8
    Oct 2009
    Townsville, Qld
    Mine comes on religiously at 80k's/hr... I think it's coz I've got 60's on the rear wheels and 50's on the front... at 80k's an hour they must be rolling out of sync and throwing the code 28.
    I'm just waiting for the tyres to get to the point where they need replacing (they were brand new when I got the car 7 months ago) and then throwing on some 18's and the VE big brake upgrade
    VZ Calais
    Aug 2005
    Mackay Qld
    Damn! that's it!
    The light never came on until i had a blow out, so i put 2 stock rims on the rear which are a much larger profile. Since then i have had the problem.
    I swapped the rims a little while back to same size all round, & haven't had an issue since!
    Thanks for the mental prompt vspantha. Problem solved.
  15. #15
    VS SS V8
    Oct 2009
    Townsville, Qld
    no worries CnG... I've thought that's been the problem with mine although I haven't tested out my theory yet. I hope getting the same profile tyres on mine will fix it all up too
  1. Engine stops, fuel light on, battery light on GOODBYE
    By scarletx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 03:43 PM
  2. vr calais head light and interoir light brake problem
    By lestat2220 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2008, 01:38 PM
  3. Berlina/Calais/Statesman Roof Inteior light into basic model with standard light
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-08-2008, 10:07 PM
  4. Converting VR Executive light to a VR Calais interior light...
    By sverzijl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-10-2006, 09:46 PM
  5. 'Rear light bulb failure' warning light
    By Misaprop in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-04-2006, 03:07 PM
