Results 1 to 3 of 3
Thread: Tacho Going nuts
    VS Statesman 5.0ltr
    Nov 2009
    Question Tacho Going nuts
    I was wondering if anybody could help me. I have a 96 5ltr statesman. I bought it a couple of months ago. When I got it it ran fine on idle, had a bit of a vibration around 2000rpm and that was it. It slowely started running rough and surging. I have replaced, dizzy cap, leads, plugs, filter, serviced the motor and trans. Was runing good for a while and is now back to surging and running rough on idle. I've noticed when it is running bad (intermitent, it dissapeared after twisting the injectors and smacking the ignition module and wiring stuff around it) the tacho bounces around when accelerating and goes nuts at idle (bounces up to 2-3000rpm) but the car is not reving.
    Does anyone know what this is?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    vr statesman 5.0 + vs exec s2 auto
    Mar 2006
    central coast, nsw
    Default tacho going nuts
    when the tacho needles start going nuts it sometimes indicates a faulty ignition coil, cheaper than ignition module as well. maybe b4 rushing out and spending money, get some carby-throttlebody cleaner and clean the throttlebody . also remove the IAC motor from the t..body ,clean it and make sure the pintle [ spring around it ] shaft can move in and out . need to use a bit of pressure to move it. dirty IAC and throttlebody can cause rough idling and surge. hope it helps........
  1. hsv tacho into berlina 5.7L standard tacho
    By genaero20 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-09-2009, 04:08 PM
  2. [VIC] VZ lug nuts with lock nuts
    By chargedvx6 in forum Parts And Other Items For Sale
    Last Post: 13-08-2009, 09:06 AM
  3. lock nuts
    By Max2 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 01-10-2008, 09:22 PM
  4. VN Tacho-Less Dash To Tacho
    By Evman in forum General Discussion
    Last Post: 01-03-2008, 08:32 PM
  5. Religious Nuts
    By Sphinx in forum Jokes/Humour
    Last Post: 30-08-2006, 02:20 PM
