Results 1 to 2 of 2
Thread: vr ss brake upgrade
    vr ss
    Mar 2006
    Default vr ss brake upgrade
    Hi all i am after a brake upgrade on my vr ss twin piston calipers and rotors front and rear
    is there anyone who has a brand new set they would like to sell? or where would be the best place to buy them without getting ripped off.
    thanks Mark.
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    I think you're referring to the VT Big brake upgrade. Or is that what you're saying you have? You can get them off ebay, BUT Dont be fooled by what some people will tell you. If you dont have the full one inch bore master brake cylinder, or you dont plan on putting one in either, dont do this upgrade. Your brake pedal will feel like a wet sponge. 15/16th's is not big enough.
    you should be able to check what you have just by looking at the brake unit under the bonnet, it will be cast into the metal.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
  1. VH Brake Upgrade
    By Lewie in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 31-05-2010, 06:30 PM
  2. vr brake upgrade
    By aphexcloud in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-06-2009, 09:53 AM
  3. Spongy Brake Pedal after VT Brake Upgrade
    By DJ Ice in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2008, 08:48 PM
  4. Vk Brake Upgrade
    By jpetrou in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 30-01-2007, 04:26 PM
  5. vt brake upgrade for vn
    By stackner in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-01-2005, 07:01 PM
