If been offered an LSD and 5spd gearbox from a VN SS, just wondering would these go into my VS?
Thanks.
is it possible to swap the bell housing on the box to use it on a 6?
thats a shame, would have been nice to add an LSD and 5spd to my VS... guess an LSD and shift kit will have to do.
is the tail shaft from my VS going to match up ok with the VN LSD?
Hi,The vn diff will fit into a vr/vs but it is about an inch narrower and looks funny,unless you've got some wide rims to fit to it.A mate fitted a vn lsd to his vr and didnt realise it was different until someone pointed it out to him.when he showed me you could just see it was a tiny bit narrower.I helped him remove it,he went back to an open wheel diff from a vs.We sat the diffs side by side,and they are exactly the same just an inch narrower for the one from the vn
Im pretty sure the VN had cable kickdown, and the VS was all electronic. I might be wrong though?
Diff was out of a vn v6 s model,I had seen the car it came from.But definitely narrower when sat side by side.I thought they would be the same too until I looked at the vr with the diff in it.You could see it was narrower.Unless someone fitted a vl diff to the vn maybe.The brake rotors were the same for both diffs and didnt need swapping.Someone here will know for sure.
