Results 1 to 19 of 19
Thread: vs looses power upon acceration
    smoken_VS is offline Perth wa
    acclaim vs 3.8L v6 1995
    Nov 2009
    miami wa
    Angry vs looses power upon acceration
    hi i got this problem with my 95 vs acclaim. It starts up ok and drive good for about 5 mins and then it starts missing when i put my foot down but drives ok at low acceleration. Ive replaced spark plugs it was good for about 1 hour and then the problem came back running like a bucket of puss again. any suggestions
    StockoVRWagz's Avatar
    StockoVRWagz is offline Formerly White50L
    '94 VR Wagon
    Feb 2008
    Northern Suburbs, SA
    could be stuffed fuel pump, crappy fuel or crap in the tank, blockage in injectors, old and dirty fuel filter, blocked air intake or dirty filter pad.
    Some of those things can be fixed by running some injector cleaner in your fuel tank.
    I had a similar problem and it ended up being a dead fuel pump.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'd reckon the next thing to replace would be your ignition leads. The fact that it improved when you replaced the plugs points to an ignition problem. They usually need to be replaced every few years.
    HoldenOnn's Avatar
    HoldenOnn is offline Roll Cage Territory
    VZ Calais Alloytec190
    May 2009
    Busselton, WA
    I had the same problem as your having when I owned my VS. I found out that it was the ignition leads as already said above. I would try these next. Get genuine or a brand name set eg Bosch etc. Don't pay hundreds of $$$ for big name leads which are not necessary.
    VS V6 Executive
    Aug 2008
    Ok, 5 mins later you have probs when u put ur foot down? I'll assume ur on the road by this stage. What if ur parked and u give it a rev once the oil presure quitens the rockers (less then 1 min), same issue? (get under ur hood and rev via teh throttle cable on the throttle body).
    Power = air and fuel (+ spark and compression).
    So if you lack power under demand then the question now becomes whats wrong with my air and/or my fuel delivery system?
    Could be air flow - not enough air getting in through the intake, filter, throttle body, manifold or valves? take ur pick.
    Could be fuel delivery - blockages, filter, pump, presure regulator, injectors, valves? once again take your pick, any of these could give said symptoms.
    Your CAT could even be semi blocked restricting flow... start at the top, test as much as possible, there are other ways to test some parts then just by replacing them (a good multimeter at $20 is cheaper then what I paid for new leads for my VS).
    I'd be checking the state inside the plenum if a major service doesn't do the trick.
    Replace fuel filter and leads. If u still have issues then you may need a fuel injector service. Assumeing u've checked a fair bit of stuff b4 hand like the air filter and as much of the top end as possible.
    However if you replace everything listed above then ur car will be alot happier even if the prob is still there and besides if u need to get a new engine u can take most of them parts over to the next one
    Theres nothing better then getting in under the hood tho and having a good listen.
    Could be somthing realy simple that takes a bit of wisdom to spot. Happy hunting and best of luck
    aceventura's Avatar
    aceventura is offline Doesn't drive like this
    Mazda 6
    Oct 2008
    SEQ
    Nov 2009
    miami wa
    its seems to be a spark problem i reackon the leads too. How do i test the fuel pump? but when the car 1st starts up its ok its only when its heats up to operational temp it fails.
    Nov 2009
    miami wa
    could it be the coil packs or the plate underneath?
    VS L67 Ute III
    Dec 2008
    Adelaide, Hallett Cove
    my VS ute is having the same problem, as it will be fine just driving but when i want the power it just "laggs" and its a manual so its usually at the end of any gear when the revs get to about 2700 just stays and wont move till i change to next gear then its fine till hits 2700ish again.
    but this doesnt happen all the time only every now and again
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    LOL can i jump on the "leads" bandwagon too
    out of curiosity, what did the plugs look like that came out? all covered in black soot or nice and clean with a light brown tint on the insulator?
    Body by Holden, Soul by Brock
    the Legend will live forever
    Nov 2009
    miami wa
    the plugs came out dirty. new plugs in the car and i thought she was fixed until the problem came back.
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Leads mate.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    VS V6 Executive
    Aug 2008
    I'd pull a few of the new plugs out and check how clean they are after having been in there for a bit just out of caution, that is not a major issue, Probly leads tho... Only happens when it's warmed up u say?
    Multimeter: Pull out a lead, set to Ohms and test resistance.
    Find out what resistance rang should be (google or speak to plenty of auto sparkys and mechanics)
    Nov 2009
    miami wa
    now ive lost reverse gear can things get any worse. im gonna replace the leads today illl see how i go otherwise its back to the old drawing board
  15. #15
    Nov 2009
    miami wa
    Its fixed yaaaaaaaaay Now i can do burnouts everywhere lol Thanks guys now ill get more speeding fines
  16. #16
    vs calais
    Dec 2008
  17. #17
    Brucefromruse is offline CRAVEN MOORHEAD
    VS executive s2
    Oct 2007
    Campbelltown nsw
    Same thing happened to me, break down under load is what the auto electrician said, new coil pac and 390 buck and all is good.
  18. #18
    1998 vs ute
    Apr 2009
    Default hey
    hey i have a 1998 vs series 3 s pack ute 5 speed on gas and fuel. it has an l.s.d to. when i trie to just sit there and smoke the wheels in 2nd gear its justs sits there and all ya smell is clutch it wont spin??? do i need a new clutch to get it to grip and spin or wat. a mates vs ute is pretty much the same and it will sit there in 2nd gear. mine wont even do that on grass in second
  19. #19
    Nov 2009
    miami wa
    I replaced the leads and its was good as new
  1. Options..power seats... power windows??
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2010, 06:01 PM
  2. Constant Power to power window switch
    By stockies in forum Electrical Wiring / Questions
    Last Post: 02-05-2009, 08:14 PM
  3. Desperatly Seeking Power + Power + More Power
    By kezza_4246 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2007, 10:28 PM
  4. Bogun Looses Control
    By summernats2010 in forum General
    Last Post: 11-01-2006, 12:24 AM
  5. head unit looses power??
    By PaRaDoX in forum Electrical Wiring / Questions
    Last Post: 06-05-2005, 12:08 AM
