Page 1 of 2 12 LastLast
Results 1 to 25 of 31
Thread: Power steering pump wont line up?
    vr clubsport
    Apr 2009
    Angry Power steering pump wont line up?
    Guys i need some urgent help, iv reassembled my engine, everything is fine except the power steering pump pulley is about a belt thickness in front of the crank pulley, has any1 had this problem, its almost like iv achieved the impossible or someone has broken into my garage and swapped my pump with a longer shaft one lol, every other pulley lines up and i cant see how else the pump and bracket can be placed.......
    VR Berlina S2
    Aug 2009
    I think you have the pulley on the wrong way haha.
    the belt lines cover the shaft it bolts onto.
    so the belt lines should not cover where it bolts onto.
    selling vp calais wheels with 97% rubber hardly used!
    vr clubsport
    Apr 2009
    Sorry thanx for the reply but don't quite understand which pulley your referring to as put on the wrong way.
    Attached is a lil drawing of my problem, im pretty sure the pulleys r right way round and the p/s pulley was never taken off the pump
    cheers.
    Attached Thumbnails Attached Thumbnails Power steering pump wont line up?-untitled.jpg
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    i would be checking how u have mounted it to the engine. check that its been bolted all the way u can and that the bracket isnt bent
    vr clubsport
    Apr 2009
    everything seems to be put on exactly how it came off according to some pics i took before, the brackets arent bent and its tight against the engine. i just cant figure it out all the other pulleys r perfect.
    vr
    Jun 2009
    hi mate, post some pics of how you have mounted it, and well be able to sort it out for you.
    vr clubsport
    Apr 2009
    hopefully these pics r helpfull, im going crazy, i bet its something so simple and right in front of me but i just cant work it out. arghhhhhhh
    Attached Thumbnails Attached Thumbnails Power steering pump wont line up?-image000.jpg   Power steering pump wont line up?-image001.jpg
    VR Berlina S2
    Aug 2009
    Ohh its for a VS.
    I was saying for a VR, sorry dude.
    vr clubsport
    Apr 2009
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    Quote Originally Posted by esaad View Post
    it is a vr
    It's a V8
    http://woteva.tk/
    If it ain't broke... I can break it for you
    vr clubsport
    Apr 2009
    vr
    Jun 2009
    are you sure this pump is of a vr? the pump and the pulleys look nothing like whats on my vr v6. i dont think ive ever seen a vr that uses a v belt. it looks like an early commodore pump.
    Attached Thumbnails Attached Thumbnails Power steering pump wont line up?-13-11-09_1211.jpg
    VR Series II Equipe smokey 3.8 + clunky Auto
    Jul 2009
    Is that the same power steering pump that cam off it? Has it been rebuilt or anything?
    Also python_hunter1, it's a V8....
    vr clubsport
    Apr 2009
  15. #15
    vr clubsport
    Apr 2009
  16. #16
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Quote Originally Posted by python_hunter1 View Post
    maybe that's because he doesn't have a v6...
    Power is measured in DECIBEL
  17. #17
    Jul 2009
    If it's the same pump untouched, then it HAS to be something to do with how it's mounted...It's been a few years since I had my V8 so can't remember if there was any special way of mountinf them...??
  18. #18
    vr
    Jun 2009
    my bad. sometimes people just need to be clearer about the engine they need help with.
  19. #19
    Jul 2009
  20. #20
    vr clubsport
    Apr 2009
    from what i can c they look the same, i can put the belt on but its on a little bit of a diagonal going into the crank...
  21. #21
    Jul 2009
  22. #22
    vr clubsport
    Apr 2009
    all other belts r fine, nothing seems to be out of place at all, even all brackets
  23. #23
    Jul 2009
  24. #24
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Do u have any photos of the engine from before it was pulled apart ?
    Can the pump mounting plate sit behind the other plate it sits against ?
  25. #25
    vr clubsport
    Apr 2009
    yeh got fotos on another computer that i referenced to, no both the bracket and plate must be like that.
  1. Changing VS power steering pump - how to fit filter in return line?
    By lordmuz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-03-2009, 12:03 PM
  2. Help required - VQ 5L power steering line
    By WNTDVT in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-11-2008, 03:46 PM
  3. Replies: 1
    Last Post: 09-11-2008, 09:18 AM
  4. oil line from power steering to steering rack
    By onmy6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-12-2007, 10:08 AM
  5. Split power steering cooiling line
    By Ruffus in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-05-2007, 11:11 PM
