Results 1 to 11 of 11
Thread: thermostat gasket
    cypher967's Avatar
    cypher967 is offline HSV VT 5.0 195i
    VS Commodore S
    Jul 2005
    Default thermostat gasket
    when replacing the thermostat and the gasket, which goes first the gasket then the thermosat? or thermostat then the gasket? cheers guys
    VR SENATOR
    Oct 2009
    Are you talking about the rubber ring? I put mine on the thermostat housing (you will see a groove for it). It did have a gasket but i removed it and only have the rubber ring.
    cypher967's Avatar
    VS Commodore S
    Jul 2005
    rubber ring?? guess i missed that then. im talking about the gasket which goes between the housing and the block.
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    it shouldnt matter, one shouldn't foul the other, if they do, i'd keep the gasket on top, so long as the thermostat is seated in it's hole and is flush witht he housing, then the gasket would do best to be on top.
    VR SENATOR
    Oct 2009
    Agree..
    cypher967's Avatar
    VS Commodore S
    Jul 2005
    VS Berlina
    Feb 2007
    VS SS V8
    Oct 2009
    Townsville, Qld
    Hi,
    I replaced the thermostat in my car about a month ago. Before you put it in, scrape out any crud from the groove on the manifold that it sits in. The top half of the manifold housing has a groove that holds the o-ring gasket, make sure you remove that... or when you bolt it on you'll snap your housing. Get some fine sandpaper (600-800 grit) on a flat surface and rub the flat side of the thermostat housing to make a nice clean surface.
    Then it's just a matter of putting in the thermostat, make sure it sits flat, if you have a bit of contact glue, put a couple of drops on the thermostat housing to hold the gasket in the groove then place it on and do up the bolts. Do up the bolts gradually on each side to keep it sitting nice and flat... and don't overtighten them... or the housing will crack/snap.
    cypher967's Avatar
    VS Commodore S
    Jul 2005
    VS SS V8
    Oct 2009
    Townsville, Qld
    No... the thermostat sits in the manifold side of the thermostat... there should be a little indent for it to sit in, then the rubber ring (which should be slightly larger than the thermostat) sits in the groove in the thermostat housing... make sure when you pull off the thermostat housing you remove the black ring to reveal the groove... if you try to bolt it up with that old gasket still in you'll snap ur housing!!
    cypher967's Avatar
    VS Commodore S
    Jul 2005
    ah ok thanks mate
  1. Flange Gasket and Exhaust Manifold Gasket
    By mrvdv85 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-09-2009, 06:46 PM
  2. Which way does the thermostat go? + highflow thermostat?
    By thek in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-02-2009, 11:11 AM
  3. thermostat and new fan
    By yobbo88 in forum Electrical Wiring / Questions
    Last Post: 14-08-2006, 06:16 PM
  4. thermostat
    By danz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-09-2005, 08:52 PM
  5. thermostat
    By sully in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-08-2005, 12:33 AM
