Results 1 to 3 of 3
Thread: 1995 HSV Clubsport Steering Wheel Vibrates
    getmymackon is offline getmymackon
    94 VR Berlina & 95 VS Executive
    May 2009
    Stratford, New Zealand
    Angry 1995 HSV Clubsport Steering Wheel Vibrates
    Hubby bought me a not new clubby and while she's a beaut she has serious issues (not me the car). The rocker covers were replaced because of the oil leak which is still leaking, the top of the radiator is leaking somewhere AND NOW the steering wheel vibrates when she is in 4th. He who thought he knew best has absolutely no bloody idea. I think he bought me an expensive lemon. HELP ME???
    666HSV's Avatar
    666HSV is offline Devils Ride
    VS 5.7 HSV Senator
    Nov 2008
    NZ
    Rocker covers are abit tricky to get to seal & if they have cork gaskets on them then there will be little chance of that have tryed them but went with the rubber ones & they where abit of a mission to sort but I got there in the end . Steering vibes , I would be getting a wheel alinement done first as they will beable to see if there is anything majorly wrong underneath that may be the problem & sort it from there . Seems strange that the vibration is only in 4th gear & not all the time maybe driveshaft out of balance , But would get alinement checked & tell them what it is doing . Unless the tank is split I would check the hose's & their clamps are tight first then look at the water pump for signs of leaking from the bearing weap hole as it may be getting old if the car has done over 100,000ks .
    See how things go & post up if ya need any help , live in New Plymouth & could come & have alook if you get stuck
    Scott > 666HSV
    Nzpure's Avatar
    Nzpure is offline VS L67
    1997 Vs Supa6
    Aug 2008
    Christchurch
    try switching your front wheels with your rears, i had a vibration in my steering wheel and i only felt it when i was cruising at 100km/h just turned out i needed my wheels rebalanced.
  1. Boss kits for VT steering wheels to fit a VZ/VY steering wheel?
    By nEb. in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-12-2011, 07:28 PM
  2. 1995 HSV VR S2 Clubsport
    By Dirbatua in forum VR - VS
    Last Post: 01-09-2009, 06:53 AM
  3. Fs: Vn/vp Hsv Clubsport Steering Wheel
    By WILDPSI in forum Parts And Other Items For Sale
    Last Post: 30-05-2006, 02:24 PM
  4. Your thoughts on replacing steering wheel with airbag to a MOMO wheel....
    By *VOLATILE* in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-02-2006, 08:36 AM
  5. Steering Vibrates/Shakes
    By anton1o in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-10-2005, 04:48 AM
