Results 1 to 3 of 3
Thread: Engine light ON! :(
    VS Executive 3.8
    Nov 2009
    Exclamation Engine light ON! :(
    Help Please!!! The engine light in my vs came on today (goes out at start up and then comes back on, stany on) changed the water pump a few weeks ago and she was running sweet, well still is if a little warm today. have poked around under the hood and also checked the fuses, listened for strange noises, checked the radiator is full and that there is no visible damage to any hoses, wires etc have only a fraction of any understanding about codes and diagnostis etc as all of my other cars have been old school metal road tripers with nothing more complicated in them than a vaccume advance! So if you can look past my ignorance and give a girl a hand I would appreciate it!!
    vs commodore
    Oct 2009
    Tamworth NSW
    Have a look at this,-the link- and then let us know what codes you get.Its easy to do.Its the best place to start for this kind of problem.Checking error codes VR/VS (Revised)
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    In addition to the excellent advice from Brett jjj, I'd like to add that I've been having virtually the same problem of late, and found mine to be a combination of an almost flat battery in the key and dirty contacts where the metal projection bit of the key contacts the ring around the ignition keyhole.
    Hope yours is as easy.
  1. Engine died at 100kmh then check engine light up ?
    By calaismity in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-05-2011, 09:58 AM
  2. HELP: VT SS Engine light and oil light coming on
    By Evilkio in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-07-2009, 10:36 PM
  3. Engine stops, fuel light on, battery light on GOODBYE
    By scarletx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 03:43 PM
  4. Battery light & Check Engine light
    By Sledge in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2008, 06:30 PM
  5. Engine Light and Trac Light
    By Quantum in forum General
    Last Post: 02-06-2006, 11:33 PM
