Results 1 to 19 of 19
Thread: does anybody want $50? im in need of help
    VS Commodore
    Jun 2009
    Frankston, Vic
    Default does anybody want $50? im in need of help
    i need someone who can tighten a handbreak. i read my gregorys but im still a little confused. i just need it to click less than 7 times (it currently clicks 8).
    i will come to you and will give you $50 for your time (should only take bout half an hour)
    im located in melbourne eastern suburbs but will travel upto 45 mins. cheers
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Ill do it, but im 2 and a bit hours away.
    Its a matter of, a 14mm(?) spanner onto the handbrake adjuster cable, takes 10 seconds (8 seconds geting under the damn car)
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    VS Commodore
    Jun 2009
    Frankston, Vic
    It says in the book you have to take rear wheels off ect. Not the case or is this true?
    Cheers mate
    1998 Mercedes Vito 113
    Oct 2009
    S.E VIC
    Quote Originally Posted by fergie_vs View Post
    Cheers mate
    Judging by what he said, i doubt it.
    Quote Originally Posted by perkoracin
    it like u pull at to a red light and they go o its that fag from just Commodores and it like u go tohe drags and ur car runs a like a 9 sec run as a eg and theres run a low 14 um i would Lol so hard like Epicly and then call them The Internet Mouthers and no go Lol thats a eg they might have Fast as rides 2 but may not sound as a Nice small block chevy with a Supercharger on it lol.
    Click here for my old VY Commodore!
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Cheers mate
    I never had, as long as there off the ground, and hand brakes released your right. Just do it up a 1/4 or 1/2 a turn until you get it right. Once you know how to do it, you will just do it by feel and test.
    A bicycle
    Aug 2009
    Gippsland, Victoria
    should be no need to take the rear wheels off, i didn't have to with mine.
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Quote Originally Posted by NonStick Squid View Post
    @old mate you drive a vs ute therefore you're a bogan therefore your point is invalid
    VR-S series II
    Jul 2009
    Darwin
    hi buddy dont pay $50 for somone to do it as said by tom its easy as
    Get under the passenger side of the car you will see a cable that comes from both wheels thats the one you need to tighten, follow the cable from the wheels it goes to a half moon shape thing with a couple of nuts (should be 2 nuts) tighten the nuts and your done.
    dont over tighten the nuts tighten a lil bit then check do this till ya get your 7 clicks
    all the best hopfully save ya $50 and 45min trip
    vr
    Jun 2009
    Commydoor's Avatar
    Commydoor is offline born in the FB era
    Vr Ss Blown
    Sep 2007
    Beresfield, NSW.
    the handbrake shoes are inside the rear disc....its like any drum brake setup....i always undid the rear caliper and swung it to the side...loosen off the handbrake then slip off the disc and check the handbrake shoes and that the adjuster isnt siezed and note which way the adjuster adjusts...fit the disc back on and remove the rubber grommet and insert the adjusting tool and rotate it in the right direction till the disc locks up and back it off 3 or so clicks...back on with the caliper and then adjust the cable till the handbrake lever comes up about 6 clicks....all done...
    note...even though its only a handbrake and not regular drum brakes the shoes can wear unevenly if you continually adjust by the cable alone over a period of time...
    vs commodore
    Oct 2009
    Tamworth NSW
    Hi,Commydoor is right ,you can adjust the handbrake at both places,I always adjust the brake shoes first(explained above but i dont have a brake shoe adjuster tool)except mine is done through a hole in the front of the disc next to the studs.Some discs dont have this hole,all I do then is remove the brake disc ,You gotta remove the caliper,two bolts.
    Then wind the adjuster with a screwdriver and refit the disc.I keep doing this until there is a sorta tight fit when the disc is put on.This is usually enough to get the shoes expanded closer to the inside of the disc and get a better adjustment,You dont want to expand the shoes so far that the shoes will rub hard against the inside of the disc,The disc /hub should still turn fairly free .Put it back together,and finish the adjustment at the front adjuster. Turn it to get about 5 or 6 clicks on the handbrake.
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Just to verify you MUST adjust the shoes first with the lever slacked right off. If you only adjust the lever the shoes will forever drag, and your handbrake wont work for crap. The lever will also feel spongy.
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    VS Commodore
    Jun 2009
    Frankston, Vic
    THANKS TO EVERYONE FOR THEIR CONTRIBUTION, SOUNDS SO STUPID TO HAVE TO DO THIS BUT THE COPY WERNT HAPPY WHEN THEY PULLED ME OVER SATURDAY NIGHT AND AS ALL WORK ON MY CAR WAS DONE SAFELY I GUESS THEY HAD TO PICK SOMETHING OUT
    python_hunter1 I WILL KEEP THAT IN MIND, CHEERS MATE
    VS Commodore
    Jun 2009
    Frankston, Vic
    So the job can be done without adjusting anything except the 2 nuts but in the long run its not all that good too?
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    If its to get it past a roadworthy or a Defect, then yes that will work. Long term it needs to be fixed properly.
  15. #15
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    my gregs says to leave it on the ground. put itin gear (or park), click the handbrake up 3 times then get under (make sure car is cold cause the exhaust will hurt) and just turn the nut clockwise untill it is tight.. $50 for a CAI or something, problem solved..
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
  16. #16
    Sep 2008
    Gold Coast
    why not just go to local mechanic work shop and get him to adjust it i got mine done for $25
  17. #17
    vs commodore
    Oct 2009
    Tamworth NSW
  18. #18
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    As said there's two places to adjust it. At the handbrake shoes inside the rear discs, and also underneath the handbrake lever. Most people just do under the handbrake lever.
  19. #19
    vs executive
    Nov 2009
    i live in frankston i can ajust it if ya still try to fix it pm me your adress our u can come to my place?
