Results 1 to 14 of 14
Thread: vs starting issue
    Holden VS S Commodore
    Sep 2009
    Default vs starting issue
    hey guys, ive read through the other threads about starting issues, ive tried the starting in neutral or park, that doesnt work, ive done a error code test to see if its a fault with the key but thats fine aswell.
    so heres the problem, i put the key in turn it to accessories they all come on fine but when i turn it one more to start the engine nothing happens, no fuel pump noise nothing, it takes about 4 or 5 turns for it to finally start and then when it starts it chokes abit and sounds as if its a bout to die but then starts fine.
    im thinking that possibly could be something wrong with the battery, i'll swap out the battery n see if it starts fine. or possibly an issue with the starter motor!
    any help/advice would be greatly appreciated!
    Quote Originally Posted by Jesterarts View Post
    With that logic, I want a cash incentive for every day I don't punch someone in the face.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Check that the battery terminals are clean and tight first.
    When you did the error check, did you wait until you got 3 "12" flashes or just one? 12 will flash 3 times before any error codes are flashed. If it is all OK then the 12 will flash 3 times again after a short pause.
    Visit my Facebook page
    Sep 2009
    Hey mate, yeah i checked the battery terminals, they are all clean and tight nothing leaking from them either.
    yeah i red about that so when i did the error check i sat there for bout 10 minutes and it flashed 12 about 9 times so i assumed it was fine.
    reading up i read the issue with the alternator red wire getting corodded and shorting, could that be a possible cause of my engine not starting because the battery hasnt got enough charge?
    thanks for your help!
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    It can be, but the engine will turn over slower than usual if that was the case.
    Does the central locking work from the key OK?
    Sep 2009
    ahh, thats what i forgot to say, the central locking works on all three doors bar the back left passenger, i leave that one permanently down because if i pull it up and lock the car that one remains unlocked and doesnt go down.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I was leading to a flat battery in the key head, but it seems to be fine.
    Take the plug off the back of the ignition barrel and give it a clean with contact cleaner.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You can also try pressing the unlock button on the key immediately after you put the key in the ignition and before you turn to start ...you should hear a soft hiss.
    fkford is offline Love The Beast!
    VS exec S2
    Mar 2009
    could be the sensor on your key..its a little circle thing that touches the round metal bits that circulate your key hole..i had exactly the same problem and that was it..if u have another key try it and see what happens..its got something to do with the immobiliser
    Sep 2009
    Quote Originally Posted by Not_An_Abba_Fan View Post
    I was leading to a flat battery in the key head, but it seems to be fine. Take the plug off the back of the ignition barrel and give it a clean with contact cleaner.
    abba, just re read what you said, and i thought i should of said that, the central locking only works when i put the key in the drivers door and open it, i have no functionality whatsoever from the unlock and lock buttons , i'll go check the spare key now n see if that has any improvement, do i need to do anything special for the spare key to recognise? i.e leave it on accessories for 30mins or whatever?
    Quote Originally Posted by hako View Post
    hey mate, i tried this but to no avail, when i try the spare key ill give this ago.
    Quote Originally Posted by deanb123 View Post
    cheers mate, ill whip out the spare key and give it a go, i think this might be the problem!
    Sep 2009
    tried this all but to no avail, its getting worse and worse now its taking longer and longer for it to start, any ideas?
    Sep 2009
    could this issue be related to the fuel pump. i was reading and people say when they turn it to start they can hear the fuel pump but i cant seem to hear this..
    VS Executive
    Mar 2009
    hi smurftec
    im having the exact same problem as you
    i cant hear my fuel pump either so we gonna have a look at that tomorrow arvo and see what the go is
    when i go to start my car the first few times i get nothin when i turn the key then i will get a clicking noise similiar to if the battey is flat then the next couple of turns the car starts
    today is the first time the car wont start and only thing i noticed is the fuel pump not workin
    so i will let ya know if this works or if you find out somethin let me know
    cheers
    Sep 2009
    yep sure thing mate keep me updated and ill let you know how mine goes
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    There have been a couple of members with similar problems and after the fuel pump was replaced it was all good. So try that.
  1. Bit of a starting issue
    By FuzzY in forum V8 Development and Modification
    Last Post: 22-10-2009, 10:31 PM
  2. Starting issue!!!
    By BIG-EV in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-07-2009, 01:56 PM
  3. Vr V6 Starting Issue
    By Chris E in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-05-2009, 10:01 PM
  4. Odd starting issue
    By SSbeast in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-11-2007, 02:21 PM
  5. Starting Issue
    By Glover0 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-03-2006, 10:29 AM
