Results 1 to 6 of 6
Thread: Extra Thermo Fan
    VS ute 3.8
    Feb 2008
    Default Extra Thermo Fan
    I have a VS Ute, with a 5 post Bull bar on it. On hot days i have some engine temp problems. It has A/C, but only one thermo fan behind the Radiator. It comes on when the temp gets to halfway. Is this adjustable in any way?
    Just wondering also, is it possible to fit an extra thermo fan, in Front of the A/C radiator?
    Could i hook it up to an over ride toggle switch?
    And is there a particular fan that would fit, after market or genuine, or universal fit?
    I have plenty of room between the bull bar and the A/C Radiator.
    Mar 2009
    some of the vr/vs came with an extra thermo fan in front of the air con rad, try picking one up from the wreckers, the wiring should already be there in your loom for it. Look for an extra plug in the loom just to the left of the main radiator as you stand in front of the car.
    VS ute 3.8
    Feb 2008
    Default Thermo fan
    Quote Originally Posted by westbad View Post
    Thanks for the info. Yeh i remeber my wifes VR sedan had two thermo fans on it, one infront of the A/C radiator, and one behind it.
    I will have a look at my wiring loom and check for the extra plug.
    Thanks again
    Wiseman.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The problem with adding the extra fan in front is that it tends to block the normal airflow thru the radiator. You could add a switch to manually kick the standard electric fan on but you are only treating a problem.....I'd be wanting to know why it is getting hot and fix the cause.
    VS ute 3.8
    Feb 2008
    Quote Originally Posted by hako View Post
    I don't have much normal air flow through the radiator, the problem is the big 5 post bull bar, is blocking ventilation, it only has a couple of small vent holes cut in it.
    But i really need it out here in the bush, and dont want to take it off.
    A fan with a switch would be good.
    Most days it's all good, just lately if it's 40 degrees, stop, start traffic in town, it gets real hot .
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You can get a 3 row radiator which doubles the cooling capacity for about $300.
  1. Extra kW
    By 5ivespeed in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-11-2008, 01:33 AM
  2. Extra Go....
    By Jenga73 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-11-2007, 04:21 PM
  3. would you like some extra dish with those?
    By V85000i in forum General
    Last Post: 29-10-2007, 06:13 PM
  4. need extra
    By VG commodore ute in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-10-2005, 03:45 AM
  5. VN SS Extra Lights
    By s_pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-06-2005, 09:53 PM
