Results 1 to 5 of 5
Thread: Engine Fuse Blowing
    VS Acclaim
    Nov 2007
    Default Engine Fuse Blowing
    Engine fuse keeps blowing, ive tried replacing it but no luck. Everytime i put a new one in i go to crank it and then it just blows again. Any ideas?
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    you have a dead short somewhere ??? have you had any work done lately or any other electrical item wired in recently ????
    VS Acclaim
    Nov 2007
    Quote Originally Posted by strgas View Post
    No havent done anything to the car lately.
    vs commodore
    Oct 2009
    Tamworth NSW
    Hi,Ive had a look at the wiring diagram in the gregorys,and that fuse sits between the battery(+12v) and the EFI relay and ECU.Id check the EFI relay under the bonnet.Just swap it for one the same and try another fuse.Hopefully its just a stuffed relay.
    shanhsv's Avatar
    shanhsv is offline Luvo
    VS Berlina V8 5speed
    May 2005
    Muswellbrook,NSW
    I had the very same problem when i converted my car to manual,the nob who did it cut wires that didnt need to be cut and one was touching the car body or something,sparky fixed it in 20min (after it was towed back to the shop after over heating 5min after i picked it up).
    WTB:VR/S HSV 250km/h speedo cluster
  1. VS BLowing Engine Fuse
    By smakked in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-01-2010, 09:55 PM
  2. Blowing fuse..
    By Lloydy1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-11-2009, 09:16 AM
  3. fuse keeps blowing
    By to_easy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-01-2009, 08:42 PM
  4. Blowing fuse VS V6
    By TrustNo1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-07-2008, 04:48 PM
  5. My car keeps blowing fuse
    By bellasmummy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-01-2008, 06:24 PM
