Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Thread: VE Brake upgrade - How to fit pads?
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Default VE Brake upgrade - How to fit pads?
    Im in the middle of fitting my VE Brake upgrade kit.
    Must say its all a piece of piss so far, except how do the squel plate things work with the brake pads, I cant work out how they go on.
    Does anyone have a diagram, photo or a really good way of describing it lol.
    Cheers, Tom
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    VS executive
    Jun 2009
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by pillzor View Post
    youre in the VR- VS section.
    Your point? Did you read the title?
    Anyone fitted the Upgrade kit and fitted those metal plate things?
    keza87's Avatar
    keza87 is offline JCCC NSW Member
    VX Wagon S3.8 M5
    May 2006
    I have the upgrade kit installed on my VX and remember that when I got them the small metal plates had been bent in transit and I had to bend them back.
    From memory they aren't top or bottom dependant and the small arms that were bent need to go close to the disk. There really was only one way to install them but required a bit of fiddling to get them into position correctly.
    Also beware that the pads go on a certain way. I made that mistake and discovered there is an inside pad and outside pad. There are 'pins' on the back of the pad which allow for correct locating on each side of the disk.
    JCCC NSW Member
    Check out my ride here : VX Manual Wagon with VZ Senator front end now Supercharged
    Just Commodores NSW Chapter. Join in for a cruise some time!
    Click here for more info
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by keza87 View Post
    Hmm, still a bit confused, might take that knowledge and go arm my self back to this stupid car.
    Currently have foot going to the floor, yet one wheel is locked on
    keza87's Avatar
    VX Wagon S3.8 M5
    May 2006
    yeah the wheel that is locked on you would have installed the pads around the wrong way. It can be difficult to get the damn thing off again.
    It doesn't sound good that the pedal is going to the floor. Have you bled the brakes properly?
    JCCC NSW Member
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Whats properly?
    They have been bled, bled and bled, still no luck.
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Hang on...
    Standard VE calipers, and mounted at the back, VS are mounted at the front. So when the VE caliper goes on the VS the bleeder nipple is on the bottom. You didnt happen to put the right on the left, and vice versa to over come this? Thats making sense to me if thats what you did, would explain air in the system and it just being gay. Gonna try anyway.
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    **** YES, Your a legend mate, figured out the clips.
    Not sure on the pads, all look the same, but will double check.
    Will try calipers on opposite sides.
    Wombles's Avatar
    Wombles is online now Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    Quote Originally Posted by Tom_1569 View Post
    Hmm, want to give me some tips to checking out the M/C, never done it before.
    Also Ill stop spamming this thread.
    PROBLEM HERE
    From memory, the pistons are held in by a couple of cir clips?
    They were a bitch to get out and put back in...
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Ok, Pads and clips are now in correctly.
    Bolt one caliper on the opposite side, it now looks right, despite being wrong, which may be right.
    Waiting for Nemesis to to come back with Maccas, then fitting the other caliper and bleeding it.
    Aiming for some 1am Road testing and bedding in, then leaving town at 8am for Marysville cruise if all goes to plan. If its the master, then **** IT, Im walking to Marysville.
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Brakes work.
    All sorted, and it pulls up ****ing hard. Throws you right into the seatbelt haha, but locks up easy in the wet, so will bed them in tomorow morning before the cruise.
    I took some photos of how the clips work, as Im sure im not the only one thats stumped, I asked a few people who looked at them, all gave a WTF expression.
    And Left claiper goes on the right and vice versa (well worked for me.
    keza87's Avatar
    VX Wagon S3.8 M5
    May 2006
    Glad to hear everything went well! Yeah I also forgot that your supposed to mount the callipers opposite to what they are stamped.
    I am surprised you did not get any instructions.
    JCCC NSW Member
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    The instructions were worse then vague, pretty much, Step 1: Fit, Step 2: Bleed, Step 3-9: Bed in procedure.
    Got there in the end, and damn happy with the results.
  15. #15
    VS UTE S3 5.0
    May 2008
  16. #16
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by 5.0L UTE View Post
    Hey bud how much the brake up grade set you back
    I think just the VE upgrade kit is $725 or $765, I cant remember, I bought a heap of other crap at the same time. Not_an_abba_fan is who I got it off.
    Definitly a worthwhile conversion, and easy to justify, running up the back of someone would have cost me 1800 in insurance claim, or half that on brakes and most likely be able to pull up
  17. #17
    Holden VS Series II 1997 Ute - 5 Speed Manual
    Aug 2008
    I have stock brakes on my VS Ute, along with 8inch tyres versus what ever the standard is. I can tell you here and now id rather pay $700 or so dollars on some fat tyres to provide the extra grip for braking then brakes for some small tyres.
    My stock brakes can lockup my wheels pretty easily. So im not sure that your comment is 100% valid.
  18. #18
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by jokerflingo View Post
    HUH?
    I just spent nearly a grand one tyres, so Im pretty sure my tyres are more than adequate.
    Bigger brakes WONT lock up as easy, they dont suffer from brake fade nearly as much, and a VS being 1996 +- they are over 10 year old brakes. Its definitly very easy to justify the slight costs in upgrading as apose to replacing the stock system.
    I didnt get them for daily performance, as I rarely use my brakes more then a light peddle, its when my ******** in his brand new Audi decides to slam his brakes on, I know I can stop to
  19. #19
    Aug 2008
    Pretty sure what ever type of brake package you have doesn't change the amount of grip your tyres have to give. If i push as hard as possible in order to stop without locking up the brakes i feel sure yours would be fairly similar, same scenario with brakes locked.
  20. #20
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    wats the size of rim needed to run ve breaks in a vs? and do u need to upgrade the booster and master?
    cheers
  21. #21
    nemesis_adrasteia's Avatar
    nemesis_adrasteia is offline better to reign in hell
    VR accliam, TF gemini, TC gemini, 79 isuzu ute
    Feb 2009
    longford, victoria
    Quote Originally Posted by jas98 View Post
    cheers
    i helped tom to do this conversion and he runs 17s, theyre pretty close you wont get 16s over them
    also using stock booster and master.
    "The mind is its own place, and in itself, can make a Heaven of Hell, a Hell of Heaven."
    apparently wasting my time with 97 cubic inches
    milk doesnt come in 1.6 litres
    my geminis
  22. #22
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    What part of having better brakes do you fail to see an improvement. I dont care when your brakes lock up, you will not pull up quicker with your brakes locked, its common sense. Compound of tyre etc is going to play a much bigger part over the width of the tyre, not to mention my brakes will be cooler than yours (under heavy braking) due to bigger discs, thus reducing brake fade etc. Really I dont care if you think my brakes are no better then your 13yr old Stock VS brakes, its a stupid argument if you cant see sense.
    cheers
    Quote Originally Posted by nemesis_adrasteia View Post
    As Nemesis said, 17"s, Ill take a photo when its not raining and Im home. But There would be around 5mm clearance between the caliper and rim. Stock master and booster is fine, as the pistons are smaller then VT or something along those lines of why it doesnt need to be upgraded like the VT conversion.
  23. #23
    Aug 2008
    HAHA no need to get all bitchy, i didn't say that your brakes are not better then mine im just saying in the same on road normal scenario there would be **** all difference. On a race track or under towing there obviously would be a difference.
    I just think your trying to make em sound better then they are.
  24. #24
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    I think your the one that has never seen or used these brakes so makes it awfully hard for you to make a comparison?
    Also you came into my thread and made the unrelated comments.
  25. #25
    A bicycle
    Aug 2009
    Gippsland, Victoria
    in normal conditions, i think there would be a significant difference, not in overall stopping power but in the 'feel' in the brakes and effort required from your foot/leg to apply them. having a better feel of what each wheel is doing under brakes can really improve the performance of the whole braking system. better feedback from the road surface means that you can brake harder as it is easier to tell how close you are to the limit of adhesion.
    i think the standard brakes in these utes are a poor effort, but are ok for road use. once you chuck a trailer on the back of them however, the extra mass and associated kinetic energy really make the effort on the pedal quite larger and i would not be 100% confident on a predicable redardation affect stopping from 100k's with a 1,000kg trailer. i know that when i put my enclosed, braked motorcycle trailer on the back of mine with only my bike and some spares and gear, i was very surprised when i tried stopping the first time.
    if this ve upgrade does what i think it would do (increase in braking power in relation to the same pressure on the pedal, better feel and a larger heat sink area), it would be a pretty good upgrade to do. less pressure required on the brake pedal on a long trip may be benefitial for fatigue etc.
    towing, the extra power would be quite helpful most situations, as the pressure you have to apply to start slowing is actually a fair bit, so it gets reduced. on the track, the ve upgrade would kill stock v6 brakes in an instant, with a bigger heatsink and better power.
    in saying that tyres are the main component to brake performance, you are right to an extent, but other things have to be taken into consideration such as suspension, steering geometry etc. if the tyres were the only thing that made a car stop really well, then why wouldn't hsv commodores of the same era as the utes in question run exactly the same brakes, just with better tyres. brakes must make a difference as i don't think the hsv brakes were anything like the stock v6 braking system....
    aww c'mon guys, play nice. i haven't seen these brakes or used them either, so i'll probably get the wrong end of the stick soon.
    now drink up, its friday night!
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Quote Originally Posted by NonStick Squid View Post
    @old mate you drive a vs ute therefore you're a bogan therefore your point is invalid
  1. What Brake Pads???
    By NVE_069 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-04-2010, 11:19 PM
  2. Which brake pads do u use ?
    By greenacc in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-08-2008, 12:41 PM
  3. Some door handles & park brake & brake pads.
    By jabsy1 in forum Parts And Other Items For Sale
    Last Post: 07-08-2008, 09:53 PM
  4. Best Brake Pads???
    By Ozzie in forum General
    Last Post: 16-07-2008, 10:45 AM
  5. How many k's from brake pads?
    By Shortstuff in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-11-2006, 07:47 PM
