Results 1 to 8 of 8
Thread: Vr caprice 5.0 wet feet?
    Haydz's Avatar
    Haydz is online now 346 cu/in
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    Default Vr caprice 5.0 wet feet?
    hey guys having a problem with my vr caprice. not sure exactly whats wrong.
    when turning a left hand corner the centre console leaks and wets the drivers left foot.
    its cold water. and has only recently been doing it. ive only noticed it with the the a/c on and i havent owned this car thru summer so havent used the a/c much.
    could it be that the plugs above the gearbox are blocked and not allowing the water to flow out of there. because as far as i knew the only water that ran thru that area should be hot. not ice cold.
    thanks alot guys
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Yep will be the drains are blocked and if it's cold thats good as it shows it's comming from the drain.
    If it's hot then you would have a real problem.
    See if you can get some wire into the drain to un block it - not easy to do in the drive way.
    and 3 Dangerous non ABS VN's
    vs commodore
    Oct 2009
    Tamworth NSW
    The A/C drain tubes that are supposed to drain the water away from the A/C are blocked.They are under the car above to transmission ,you can see the holes going into top of the trans tunnel/floor of the car.They need somthing stuck up into these holes to unblock them,but dont use a screwdriver or piece of wire because you can damage the A/C evaporator,use long plastic zip ties or somthing similar to do the job.
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
    cheers for that guys. ive seen the a/c drain vents before. but i had the gearbox out. any tips etc on how to clean them without removing major driveline components.
    88GreenVN's Avatar
    Jun 2006
    As said above - long zip tip (Morton screw). If you get a larger one that is reasonable strong and about 300mm long - that should do the trick. It's only dirt in the drain generally and so should not take much to un block.
    You will need the car up on stands so you can get under and into the drain. Much easier on a hoist if you can find one to hire cheap.
    VXII
    Nov 2009
    Sometimes the tube comes out of the evaporator box inside the car too, and the water just pours out of the empty hole. Get down under the air conditioning and check the tube that drains the evap hasn't fallen out of the bung.
    MasterOfReality's Avatar
    MasterOfReality is offline Thats Dr to you.....
    VP HSV Enhanced Calais, 2006 Suzuki Grand Vitara
    Feb 2004
    Where the mines are
    Also, like in my car, the footwells get really hot due to the extractors, and I get a lot of condensation on the box and this drips into the footwells. My aircon is a bit too cold though, it comes out of the vents at 3 degrees.........
    Although prob just the drain tubes blocked.
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    There real easy to clean if you take your dash and HVAC out haydz!
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
  1. Wet Feet
    By Sway_OnVY in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-10-2009, 09:43 PM
  2. Hot Feet??
    By Milky2106 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-12-2008, 06:51 PM
  3. hissing near feet
    By robby88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-02-2008, 05:50 PM
  4. Hot Feet
    By hardlyevolved in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-01-2007, 07:09 PM
  5. Wet Feet
    By sharpeidog in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-02-2005, 06:51 AM
