hey guys does anyone have a guide to changing the front brakes in a vr vs commodore, is there a guide on this sitee i looked but couldnt find one.
thanx any help appreicated
Usually you will find something in the "how-to" section. I've found this for you which should do the trick:
VN - VS: Replacing the Brake Pads (Disc Variety)
After you have put the wheels back together (following the steps from that thread posted above you should SLOWLY push the pedal down. Not to damage anything in the master cylinder. Because sometimes you can stuff the rubber seals up that hold the brake fluid in there and give the pressure to the pads.
thanxx alott guys i realy appricate it
