Results 1 to 7 of 7
Thread: HARD shifting when engaging gears from park
    VS l67 statesman
    Dec 2008
    Default HARD shifting when engaging gears from park
    The statesman gearbox has been starting to play up the last couple of times Ive driven, it is holding gears longer than normal and changing at strange times
    But the main problem is when engaging gears from park it slams into gear with a jolt and jumps forward
    Anyone got anyideas what it could be and how to fix .........sticking servo maybe?
    Wombles's Avatar
    Wombles is online now Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    Maybe try giving it a good tranny service and see how it goes from there?
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Is your engine idle speed higher than normal? Have you displayed your DTCs (trouble codes)?
    VS l67 statesman
    Dec 2008
    I tried it again last night after sitting for 40minutes and it was well behaved so it seems to be coming and going ,As for the revs I sure they were ok but I will double if it happens again and I dont have the gear to check the codes
    N/A
    Apr 2009
    VIC
    It may be your uni joint. tailshaft diff..very cheap fix. very common problem. get it checked out
    VS l67 statesman
    Dec 2008
    yeah it also started to shift eratically today at strange times after driving it for approx an hour, I just took it for a spin after changing the TPS its good at the moment but I'm not holding my breath as this problem keeps coming and going
    vr calais 5ltr
    Aug 2009
    nsw
    Quote Originally Posted by vsl67 View Post
    you don't need any gear to check the for fault codes mate just a paper clip
    Checking error codes VR/VS (Revised)
    all you need to know there matey....
    My Ride:
    vr calais 5ltr (gone to the darkside)
    Previous rides:
    zj fairlane 351c, nf2 fairlane 302w, ef fairmont str8 6, ef2 falcon str8 6, ef fairmont ghia str8 6
  1. VP stalling when shifting from park...
    By jonnydico in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-09-2010, 04:50 PM
  2. Like shifting gears? Have a look here...
    By VT-565 in forum Parts And Other Items For Sale
    Last Post: 26-02-2009, 09:09 PM
  3. VP Hard Shifting/Kick
    By Hardstylin in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-11-2008, 11:36 AM
  4. scraping sound when shifting into Drive/Rev from Park
    By Loungefly in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-02-2007, 10:49 AM
  5. revs to high and gears not shifting right
    By timboss04 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-11-2005, 04:35 PM
