Results 1 to 22 of 22
Thread: What is this for?
    holdendude's Avatar
    holdendude is offline ŞuρξЯŞ†★Ř
    *AL4SHO* VR Commodore
    Mar 2009
    Geraldton, WA
    Question What is this for?
    Hey guys, today when i pulled out my center console, i noticed some wires & a plug sticking out with nothing attatched to them! just wondering what it could be for? Any help would be great!
    And also with my Ciggy Lighter Illumination light it only has room for 1 wire to connect in the socket but at the other end of the wire there is the pulg & it has room for 2 wires but only 1, is it supposed to be like this or what?
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    Could possibly be for the auto gear shifter light. Its just a part of the wiring loom so if you ever convert to auto, you got the plug to light it up.
    holdendude's Avatar
    Mar 2009
    Geraldton, WA
    Quote Originally Posted by Verynice View Post
    So is that in every Factory Manual vr?
    Verynice's Avatar
    VS Caprice 5L
    Aug 2008
    VS L67 Ute III
    Dec 2008
    Adelaide, Hallett Cove
    i have this plug in my VS ute and its not doing anything either mine is also manual
    STEALTHY™'s Avatar
    STEALTHY™ is online now So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    That is for rear footwell lights/centre console light. Plugged it into the wiring already on the statesman console i bought, and everything lit up
    Your welcome.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    vs commodore
    Oct 2009
    Tamworth NSW
    Hi,If that wire is Brown with white trace, according to gregorys that is the automatic shifter light.Does it look like a small push in bulb will go in the end of it?The centre console and rear footwells connect to an orange with black trace wire.
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by Brett_jjj View Post
    Just by looking at it, you can see its a plug, not a light socket.
    cheers sexy
    shanhsv's Avatar
    shanhsv is offline Luvo
    VS Berlina V8 5speed
    May 2005
    Muswellbrook,NSW
    I just had to go have a look myself and im sure its for the auto shift light, by looking into it theres meant to be a wedge type globe in it
    Rear footwell lights? Where are they hidden
    WTB:VR/S HSV 250km/h speedo cluster
    STEALTHY™'s Avatar
    Jan 2005
    Weird, mine plugged straight into the loom on the Stato console and the lights worked. And my car was auto from factory aswell (Converted now)
    Maybe it has 2 uses?
    cheers sexy
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by STEALTHY™ View Post
    Try looking at a wiring diagram before you shoot someone down in flames.
    STEALTHY™'s Avatar
    Jan 2005
    Why? Just a month ago i put a statesman console in my car, had a plug on the console and it fit right in the plug pictured, and it was for the rear footwell lights and centre console light.
    As mentioned, my car was a factory auto aswell, so technically there should still be a plug for the trans lights, but THAT plug pictured, was not it.
    cheers sexy
    vs commodore
    Oct 2009
    Tamworth NSW
    well you are connecting them to the wrong wires,the wiring diagram from the manual shows centre console and footwell lights connect to orange with black trace wire.and its not a plug ,its a globe socket anyway.
    STEALTHY™'s Avatar
    Jan 2005
    Well they fit, and havn't blown any fuses (and from what you said, wouldn't connect if its a socket....)
    The thing pictured is EXACTLY the same position (the break in the factory loom, on the side of that bracket) as my car was, and was the plug for the loom.
    cheers sexy
  15. #15
    Verynice's Avatar
    VS Caprice 5L
    Aug 2008
    All the footwell lights etc run off the interior light wiring, so when you open the doors they light up. That plug however, lights up when you turn your parkers/headlights on.
  16. #16
    STEALTHY™'s Avatar
    Jan 2005
    Just saw his 2nd post, says its a factory manual VR. Why would a factory manual loom have the plug for an auto light?
    cheers sexy
  17. #17
    vs commodore
    Oct 2009
    Tamworth NSW
    That part of the loom is universal fit I guess.Theres always extra stuff like this in all cars,Ive seen it a million times.I was only going on the wiring diagram in the gregorys for what Ive said above, and I had to replace the auto shiter light bulb in my car once before and it looked like the same bulb holder as mine,Im not here to argue with anyone ,Im the first to admit when Im wrong about somthing.If a "good"auto sparkie got on here and said (that wiring diagram is wrong ,its like this),then Id be saying ok then.I think that if you have plugged your plug into that,and it made contact inside,it could still power your lights anyway.
  18. #18
    STEALTHY™'s Avatar
    Jan 2005
    That part of the loom is universal fit I guess.Theres always extra stuff like this in all cars,Ive seen it a million times.I was only going on the wiring diagram in the gregorys for what Ive said above, and I had to replace the auto shiter light bulb in my car once before and it looked like the same bulb holder as mine,Im not here to argue with anyone ,Im the first to admit when Im wrong about somthing.If a "good"auto sparkie got on here and said (that wiring diagram is wrong ,its like this),then Id be saying ok then.I think that if you have plugged your plug into that,and it made contact inside,it will still power your lights anyway.
    Win for me then. I just pulled the ash tray out to see what i could see in there, but that side was covered (and cbf taking the whole console out).
    All i saw that wasn't plugged in was a 4 wired plug (Same plugs that plug into the back of the switches under the radio) which is different again (but might be something to do with the auto)
    cheers sexy
  19. #19
    vs commodore
    Oct 2009
    Tamworth NSW
    well it has got me stuffed then what the go is with it,maybe someone else knows somthing about it .Ive got a wrecked vr at my other place,I will have a look at that and see how it is,I will put here what I find .And as for winning goes the bloke who asked this question has won sweet FA from either of us.
  20. #20
    STEALTHY™'s Avatar
    Jan 2005
    i meant win for me, because the loom i plugged into worked Thats always a good thing
    cheers sexy
  21. #21
    vs commodore
    Oct 2009
    Tamworth NSW
  22. #22
    VYII Acclaim
    Jun 2008
    Largs Bay, Adelaide, S.A
    Brown/white is the interior illumination. Comes on with the headlights/parkers. Stick a small wedge bulb in and turn your lights on... it should light.
    Or check it with a multimeter or test lamp.
