Results 1 to 6 of 6
Thread: vr temp?
    vr executive
    Nov 2009
    Default vr temp?
    hi all
    just wondering what temp a vr run at? what degrease?
    StockoVRWagz's Avatar
    StockoVRWagz is offline Formerly White50L
    '94 VR Wagon
    Feb 2008
    Northern Suburbs, SA
    Not sure if it's what you're after, but my new VR runs at around 1/4 on the gauge. Less than that on cooler days, but when we had 43 degrees in Adelaide, it only went just above 1/4 driving then up to half when sitting and idling for a bit but straight down to 1/4 when driving again.
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    Quote Originally Posted by StockoVRWagz View Post
    my old VR SS and current VS V8 are the same, however there are a few people on here reckon their VR-VS's sit on half when cruising and 3/4 when idling at the lights
    vy ss ute daily hj gts project
    Aug 2008
    they should run at about 98 degrees so i'm told and they boil at about 125.
    VP Exec
    Jun 2005
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Temperatures are not on the gauge - my experience is that anywhere from 1/4 to 1/2 normal running and up to 3/4 stop/start or up a steep hill. Closer to H means the engine is getting into the danger zone.
  1. oil temp/water temp gauge wiring
    By HUMBLZ in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-05-2011, 04:53 PM
  2. normal running temp for a VT 5L? and temp gauge..
    By mike49 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2009, 12:57 AM
  3. Q's regarding Coolant Temp & Intake air temp sensor
    By Steven M in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-02-2009, 05:08 PM
  4. gauges oil temp and engine temp
    By vzon20s in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-11-2008, 05:31 PM
  5. Electric oil temp and water temp gauges
    By FRESH_VR in forum General
    Last Post: 02-09-2008, 04:27 PM
