Results 1 to 8 of 8
Thread: Floor mounting brackets/holes in VR for cargo barrier
    StockoVRWagz's Avatar
    StockoVRWagz is offline Formerly White50L
    '94 VR Wagon
    Feb 2008
    Northern Suburbs, SA
    Default Floor mounting brackets/holes in VR for cargo barrier
    I picked up a freebie cargo barrier and grabbed all the brackets and bolts from the wreckers, and in my wagon there is no holes in the floor for it to mount to, or am I looking in the wrong place for them. The wagons at the wreckers had holes on both sides next to the wheel arches. I've seen that to get it mounted in a workshop costs $120+, as we haven't got massive amounts of funds at the moment I was hoping to put it in myself
    Also, before the search nazi's come along, all I have been able to find on here, google and another commodore forum is people asking for help but no answers lol.
    Paul.
    Dec 2007
    you may have to pull up the carpet and look underneath, I had a vt that I installed on in and had to cut holes in the carpet to get the bottom hooks through
    '94 VR Wagon
    Feb 2008
    All the carpet is up because I had to lift it up to see where I had to put the babyseat bolt in. I've checked under that and there's no holes, except the 3 for the babyseats and the 2 covers for the top of the shocks.
    vy ss ute daily hj gts project
    Aug 2008
    A lot of times with things like that put the barrier in place mark where the bolt holes are and drill a small hole and you will find a welded nut there. Then its just a simple matter of grinding it out with a die grinder. I've never fitted a cargo barrier but its happened to me a fair few times with seat mounts.
    '94 VR Wagon
    Feb 2008
    Quote Originally Posted by love the general View Post
    Might give this a go, but the ones at the wreckers just had what looked like holes from factory with a metal bracket bolted to it which had the thread that connected the barrier to the body.
    '94 VR Wagon
    Feb 2008
    I scrapped back some sound deadener where the bolts and bracket should go and I find this. If you can't make it out its just a bare metal plate, not sure what it is though. When I finally get this thing in, I'll be doing a workshop article about it so noone else has to go through it, since all I found is people asking how to do it as well lol.
    Driling wont help, because from what I've seen, VR's dont have a welded nut underneath. Can anyone help?
    Attached Thumbnails Attached Thumbnails Floor mounting brackets/holes in VR for cargo barrier-100_0602.jpg
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    A couple of quick shots that I just took of the bracket in my wagon. I cannot pull the carpet back any further due to the bracket.
    Attached Thumbnails Attached Thumbnails Floor mounting brackets/holes in VR for cargo barrier-23112009.jpg   Floor mounting brackets/holes in VR for cargo barrier-23112009_001.jpg
    '94 VR Wagon
    Feb 2008
    Thanks heaps for that!
    Looks like I'll be drilling those 3 holes either side myself, as where yours is bolted to is the exact place in the pic of mine I posted and I recon I have to put one of the brackets underneath the floor for the bolts to screw in it.
  1. VZ Cargo Barrier
    By dave0103 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: Yesterday, 06:29 PM
  2. Cargo Barrier
    By jimbojones889 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-04-2009, 04:11 PM
  3. VT cargo barrier
    By roby02 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-10-2007, 06:30 PM
  4. Position of mounting points for a cargo barrier?
    By millsy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-06-2005, 11:44 PM
  5. Where to get a cargo barrier fitted
    By aa23 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-05-2005, 08:35 PM
