Results 1 to 4 of 4
Thread: changing crank seal
    vr calais 5ltr
    Aug 2009
    nsw
    Default changing crank seal
    ok so i have to change the crank seal im fairly certain its called. the one behind the harmonic balancer had a quick search and couldn't find anything on it.
    how hard is to change and do you have to pull out the the hole crank to change it? could someone explain how to do it in a quick step by step cheers
    My Ride:
    vr calais 5ltr (gone to the darkside)
    Previous rides:
    zj fairlane 351c, nf2 fairlane 302w, ef fairmont str8 6, ef2 falcon str8 6, ef fairmont ghia str8 6
    Commydoor's Avatar
    Commydoor is offline born in the FB era
    Vr Ss Blown
    Sep 2007
    Beresfield, NSW.
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    its just a press in seal. remove the balancer, tap an edge in without damaging the bore pry it out. clean the bore in the timing cover, put light gak on the outside of the new seal. put it on square and tap it on using sum pipe. sorry i couldnt describe it better im just thrashed
    vr calais 5ltr
    Aug 2009
    nsw
    thats good enough cheers mate sounds fairly easy
    My Ride:
    Previous rides:
  1. [308] Changing the rear main seal
    By DANNY8 in forum V8 Development and Modification
    Last Post: 09-09-2009, 09:45 AM
  2. How to change the front crank seal in vp v6
    By Abrowne70 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-03-2009, 08:54 AM
  3. Should I replace the front crank seal?
    By Wagon_Wheel in forum General
    Last Post: 21-12-2008, 01:16 PM
  4. Changing the rear main seal...???
    By ruredi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-04-2007, 08:50 PM
  5. Changing 5.0 litre rear main seal
    By hopo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-01-2006, 09:19 PM
