Results 1 to 15 of 15
Thread: VY exhaust on VR
    VR Acclaim v6..?
    Feb 2008
    Gold Coast
    Default VY exhaust on VR
    Hi all
    Just wondering if anyone knows whether an exhaust system from a Vt-Vy SS would fit onto my VR (IRS + LS1) so same engine and such
    Shop where i bought the engine from reckons it will but im not so sure?
    anyone have any idea?
    cheers
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    wait, your VR has an LS1? are you sure? Unless you converted the engine, its going to be a 3.8L Buick or a 5.0L Holden, not a 5.7L Chev.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    No, it won't bolt straight up. The front is different and the rear is different. The hangers on the middle mufflers will line up (sort of) with the hangers on the car, but everything else will need modifying.
    Visit my Facebook page
    VR Acclaim v6..?
    Feb 2008
    Gold Coast
    Im in the process of converting it
    just sussing out which exhaust to go with pretty much set on a twin 3" xforce system sounds so good
    So you reckon it will fit but hangars will need to be modded?
    cheers
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    No, the other way around, the hangers will fit but the rest of the system will need modding.
    VR Acclaim v6..?
    Feb 2008
    Gold Coast
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    No it isn't. If it was just hangers that needed changing, a cut and a weld. With the rest of the system, you will need to remake the front section so it lines up with your cats, redo the pipes under the axle, and remake the rear section.
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    is your VR fitted with IRS in the rear or does it have a live axle setup?
    Body by Holden, Soul by Brock
    the Legend will live forever
    VR Acclaim v6..?
    Feb 2008
    Gold Coast
    In that case sounds a bodgy home made exhaust could be in order instead of paying for one lol
    Mine is IRS i think that makes a diference? lol
    Apr 2006
    Auckland NZ
    yeah, you should be able to make it work. if it was live axle then you would need to make the part that goes over the diff.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The differences are the cat locations, they are in a different spot, and where the pipes go under the axle and out the back, the VR runs closer to the centre of the car because of the spare wheel, and the VT-VZ runs right out closer to the outside because there is no spare wheel well there.
    VR Acclaim v6..?
    Feb 2008
    Gold Coast
    CANYONERO's Avatar
    CANYONERO is offline Likes Cheese...
    V8 6spd wif MOMO leavaa.
    Mar 2006
    Country SA
    Quote Originally Posted by Vee-ard View Post
    wait, your VR has an LS1? are you sure? Unless you converted the engine, its going to be a 3.8L Buick or a 5.0L Holden, not a 5.7L GM.
    i fixed it for you
    vs commodore
    Nov 2009
    pretty much if your goin through the trouble of doing that converssion dont be a tight ass and get an exhaust made
  15. #15
    VR Acclaim v6..?
    Feb 2008
    Gold Coast
    alternatively u could look at it as Ive spent sh*tloads of money on it already and hence anything I can get done on the cheap to save a few bux is a plus and means i get it finished sooner
  1. [SA] Swap VY custom exhaust for standard vy exhaust
    By SAV_117 in forum Swap / Wanted to Buy / Trade
    Last Post: 09-09-2009, 09:20 PM
  2. Exhaust / Catalytic flanges, Exhaust swapping
    By social in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2009, 11:02 AM
  3. Wanted VS V8 exhaust / HSV exhaust / Merge pipe
    By prettyboringbloke in forum Swap / Wanted to Buy / Trade
    Last Post: 21-02-2008, 03:06 PM
  4. List Of Exhaust Quotes no it's not another exhaust question:)
    By Thomas1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-11-2006, 08:57 AM
