Results 1 to 6 of 6
Thread: VR ignition problem
    VR COMMODORE
    Nov 2009
    Default VR ignition problem
    Hi there I recently bought a VR Executive V6 which had been sitting in a back yard unprotected for the last six months,I replaced the battery and it started straight away,however since then it will only start intermittently. The lights,horn, radio and everything else work,but when you switch the key on it does,nt turn over ,if you come back later it may start OK,regards Callum .
    Commodore VR 93
    Nov 2009
    Does it click or refuse to turn over? Or just no response whatesoever when ya try to start ignition past music/aux power. Because I have a VR exec v6 sedan that has the same problem, you just gotta turn key back to start and give it another go. I.e turn it back to original position as if you had just put it in, then turn it over again and it'll be right.
    Should get the ignition barrel replaced though, once you figure out the extent of the problem.
    Here is a thread:
    Key Won't Turn in Ignition
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    connections to the starter motor give it a clean and put the wires back on
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Do an error code check to see if it has logged any codes. Checking error codes VR/VS (Revised)
    Visit my Facebook page
    VR COMMODORE
    Nov 2009
    thanks guys , the metal pimple on the key is worn so I bent the metal strip beside the barrel to make a better contact which seems to have solved the problem,regards Callum.
    VN commodore
    Jan 2010
    Smile i lost my keys
    hey every one i lost my keys and now i need to replace the ignition barrel with a new set of keys in my 1990 VN commodore and it would help greatly if someone knows how to get it to the on position so i can remove the barrel i dont mind about breaking the barrel itself cause im replacing it so plz some one help me
  1. VZ SVI LPG Ignition Problem
    By Weekend Warrior in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 15-04-2009, 04:52 PM
  2. ignition problem?
    By DANVSUTE in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-07-2008, 04:25 PM
  3. Ignition problem help needed, Ignition lead fallen out??
    By boourns in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-06-2008, 05:04 PM
  4. VR Ignition Problem?
    By Radar in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-02-2008, 04:33 PM
  5. Ignition Problem
    By trombetta in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-12-2006, 10:15 AM
