Results 1 to 17 of 17
Thread: Replacing brake pads & discs.
    VS Auto Executive
    Nov 2009
    Default Replacing brake pads & discs.
    I just replaced my front brake pads. VS Commodore stops fine but squeals now. Did NOT machine discks although it went metal to metal. REPCO r selling pads, rotors and fluid packs for $99 front or rear. Should I go to the expense (and trouble) of changing pads again and installing NEW rotors? Will it stop the car any better now the pads have bedded in?
    Appreciate some feedback ( I know what the RIGHT answer is but I want to know what the common sense answer is).
    Dimitri Milewicz - PAKENHAM
    Dec 2007
    wikky is offline ............
    VZ SSZ
    Mar 2008
    Here
    I'd at least get the rotors machined, if they've got enough life left in them, and a new set of pads. Repco selling rotors, pads and fluid for $99? Holy crapshit! Can't be too much chop for that price.
    At the end of the day, you don't want to cut corners with your brakes. They do come in handy once in a while.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If it went metal to metal you probably have some deep groove in the discs - because of this the pads will take time to wear into the grooves and in the meantime will squeal. Give it about 1000KM of city driving before you start worrying UNLESS the brakes are pulling to one side or need excessive pressure to stop.
    vt ss, vr calais, vt berlina wagon(family bus)
    Aug 2008
    adelaide
    if there is enough meat left on the discs id defo get them machined, it dont cost that much. even take them into a local engineering shop and get them to do it. i do mine on the lathe at work during smoko
    vs commodore
    Oct 2009
    Tamworth NSW
    Hi,I found that when I fitted $30 pads from supercheap, they squealed like mad,I ended up buying bendix brand,(double the price),no squeal at all from them.I had fitted 4 new disks with the cheap pads.Just cheap s#*t pads causing it.
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    What pads did you fit Dimitri, and how bad are your rotors looking ?
    If repco's rotors are DBA or RDA i'd consider buying them , but the pads will certainly be rubbish.
    Wombles's Avatar
    Wombles is online now Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    Usually cheap and nasty pads will squeal.
    You want fairly expensive ones and they shouldnt do it..
    Get the rotors machined too. Thats just stupid to leave them...
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    measure your disc's if they will take a machine then do so if not replace them and reface the pads and rebed them in again ???
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    Re face the pads?
    Hmm...
    I tryed scrubbing my pads on concreate (supposibly a bad idea?) Now they squel crazy as well...
    My Commy
    Discuss.
    strgas's Avatar
    Oct 2009
    yep bad idea that one , next time try some sandpaper on a flat surface or wrapped around a file
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    Hmm... What grade sand paper. I think I should do that next time I fiddle with the wheels lol.
    My Commy
    Discuss.
    strgas's Avatar
    Oct 2009
    p80 works well also clean the backing plate of the pad and apply tile adhesive to it to stop dust build up between the plate and piston ..
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    I only got the brake pad on concreate idea from a mate that works in a mechanics... I'll try the flat sand paper idea. Haha.
    My Commy
    Discuss.
  15. #15
    strgas's Avatar
    Oct 2009
    have done it myself in the past but always finish it off with sand paper . have used anything from the old repco red brake pads to bendix ultimates , QFM , firepower , cheap and nasty thru to top of line pads race and street always will get some squeal from time to time.
  16. #16
    Manual VS
    Nov 2009
    SA - South
  17. #17
    strgas's Avatar
    Oct 2009
    Quote Originally Posted by Weapon View Post
    get vt upgrade package....
    oh yeah thats the best way to go , work well on the front of my VL and now have a set to go on my WB tonner with VT disc brakes for the rear too one day soon ...
  1. VN/VP V8 Rear Brake calipers with brakes pads + discs
    By georgeonboost in forum Parts And Other Items For Sale
    Last Post: 10-05-2008, 03:47 PM
  2. Replacing VT front brake discs and pads
    By flukey77 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-11-2006, 10:25 PM
  3. New Brake Pads + Machining Discs
    By thisispete in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-02-2006, 03:10 PM
  4. Larger Brake Pads On Standard Discs?
    By Evman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-11-2005, 09:18 PM
