Results 1 to 9 of 9
Thread: VS no go
    vt acclaim wagon v6
    Jul 2009
    Default VS no go
    HELP! Have a VS that won't start. I Checked spark and it seems fine.
    When car starts it dies almost immediately.Sounds like it's out of fuel,but I put more in it to be sure. any suggestions would be helpful.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Have you pressure cleaned the engine lately, or degreased it, if so it could be water in the oil pressure switch - this supplies power to the fuel pump and if it gets wet and corrodes the result is much the same as you describe.
    vs commodore
    Oct 2009
    Tamworth NSW
    Also check the fuel pump itself,can you hear it when you turn the key to on(not start).It should go for about 2 seconds,then stop.
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Dirty fuel filter mybe. When did you last replace it?
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    VS Berlina 3.8
    Dec 2008
    VS l67 statesman
    Dec 2008
    standard VS wagon (not for long)
    Nov 2009
    darwin
    hey im just wondering if that answer could be the same prob im having with my vs wag
    VS l67 statesman
    Dec 2008
    I had a vp with a faulty emobliser it would either die on start up or stall with no warning while driving luckily it had the overide switch in the passenger side door jam so I could shut it off
    vs commodore
    Oct 2009
    Tamworth NSW
    Ive read on here that the actual alarm keylock in the door jamb is the cause of this problem.It gets a bad connection inside it.My oldies own a VP and someone has removed the keylock from the door jamb altogether.Their immobiliser still works though.I guess they just cant turn it off. Does anyone know if you can buy these anywhere?
