Results 1 to 3 of 3
Thread: !!Car nearly didnt start out of the blue??
    vr executive
    Nov 2008
    Default !!Car nearly didnt start out of the blue??
    hey guys
    i stoped at the petrol station today in my vr v6 and filled it up. after i payed and went to start my car it nearly didnt start. (asif it had a flat battery) But it just turned over and started. When i got home i turned it off and started it again. It started fine this time. Any ideas what it could be? My battery is pretty crappy but i think my startor motor and alternator are orite....
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    My car does this when its warm, the starter motor gets too hot because it never had the heat shield mod, and it sits really close to the extractors. It cranks really slowly and sounds exactly like what you're going through. Its a V8 though.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    VR Statesman
    Sep 2006
    If your battery is a few years old it's probably you battery if not it's probably your regulator on the alternator.
    My mum's vr had an intermittent starting problem a few years ago that turned out to be the oxidation on the terminals. Would run fine but sometimes crank week and sometimes didn't quite get there.
  1. vz sv6 blue smoke on start up
    By kiwi nz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 21-01-2012, 11:34 AM
  2. WB Statesman blue 308 motor wont start..
    By BOGANV8 in forum General
    Last Post: 03-08-2008, 04:52 PM
  3. Car Nearly Didnt Start???
    By S Pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-07-2006, 09:55 AM
