Results 1 to 22 of 22
Thread: When do your breaks need to be upgraded?
    Manual VS
    Nov 2009
    SA - South
    Default When do your breaks need to be upgraded?
    howdy,
    in a vr or vs,
    at what point do the breaks need to be upgraded to pass regency with a new high powered engine? making around 250rwkw.
    or dont they need to be upgraded?
    Also - would a vs berlina series 2 be live axle or irs?
    STEALTHY™'s Avatar
    STEALTHY™ is online now So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Could be either, IRS was optional (Only standard on Calais, and maybe SS)
    You should upgrade the brAkes either way. Its not like it would ever be wasted money.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    VS Berlina 3.8
    Dec 2008
    Pretty sure IRS was standard on Berlina's and Acclaim's, not sure about VP though.
    What kind of engine is it? If the engine came from the factory, I assume power output isn't an issue in regard to upgrading brakes (although you'd be mad not to upgrade them). Although upgrading them may require an engineers cert. or mod plate or whatever.
    You'd be better off looking up the laws for you state or talking to the RTA or what have you.
    StockoVRWagz's Avatar
    StockoVRWagz is offline Formerly White50L
    '94 VR Wagon
    Feb 2008
    Northern Suburbs, SA
    Even just going to VZ brakes would be worth it. Cheap and better than VR/VS, and the V6 and V8 brakes were the same. Wouldn't know about master cyclinder and all that kind of stuff, as all I did was assemble the front brakes/struts and the IRS.
    '94 VR Wagon
    Feb 2008
    Now I think about it the SSZ premium upgrade package was the only difference. Bigger rotors and calipers and had the M14 steering knuckle instead of the smaller M12, rears were practically the same, slightly different rotors and pretty much standard calipers painted red (or oprional grey in the later models)
    I could have made up front and rear kits consisting of: Front rotors, calipers, M14 knuckle and bolts, LCA and rear rotors, calipers for $790. Gotta love factory cost price
    ryno_vrx's Avatar
    ryno_vrx is offline Donating Member
    VR HSV enhanced Berlina
    Nov 2008
    Mirani
    in a vr/s the brakes should be upgraded immediately after the car is taken from the factory as the brakes are shit, i mean in my case sure they'll stop me unless theres a strong tail wind, then i'm fighting a losing battle....
    oh irs is standard on berlinas i think you'll find
    whats the difference between my missus and my blower??
    well they both whine but the blower actually puts out
    STEALTHY™'s Avatar
    Jan 2005
    No, IRS was optional on all VP-S Berlina's. VT Was the first that it was standard (When it was standard across the whole range)
    Was standard on Acclaims tho (Safety model)
    cheers sexy
    Manual VS
    Nov 2009
    SA - South
    Okay cheers guys,
    Yeh i dont have standard breaks on my vs - ive got the VT break upgrades and i think they are good enough.
    Ive been told that i need to find out about the breaks which came on the car with the engine i want and get as good if not better breaks for my VS project.
    Also - the ECU im getting with the engine and trans has been tuned allready and has a seperate motherboard; Could i get it tunned once again to say change gears before boost by about 250-300revs(with eco selected) - unfortunently itll be an auto ovc., and then with the power button selected change at 5,000odd.
    thedeadwalk's Avatar
    thedeadwalk is offline thedeadwalk
    VS executive S2
    Sep 2009
    newcastle
    i simple rule when doing performance work to a car start from the ground up man factory rolling stock was not made to put up with any thing more than its already got
    Manual VS
    Nov 2009
    SA - South
    I dont thrash any cars, they break too easy - and not to mention myself.
    Thanks for your input though.
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    Quote Originally Posted by Weapon View Post
    Okay cheers guys,
    If you want it to change earlier, lift your right foot.
    My VS berlina is live-axle, but I have seen an IRS one around so I'm pretty sure it was an option from factory
    Manual VS
    Nov 2009
    SA - South
    yeh, but id rather get the ecu tuned so it does it for me - after all isnt that the whole idea of an auto? lol
    if not i might have to see what mods can be done to the auto to make it fully manualised.
    Philthy's Avatar
    Aug 2005
    So you want it to change gears at the same revs no matter how buried your foot is? I could be wrong but I don't see that happening
    STEALTHY™'s Avatar
    Jan 2005
    I already said, VS Calais and Acclaim IRS is standard (And maybe SS too). All others its optional. Mate of mine owned a VS Berlina with every calais option from factory, don't know what the dude was on when he bought it, cause he would have payed shitloads more than an actual calais.
    cheers sexy
  15. #15
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Quote Originally Posted by STEALTHY™ View Post
    Wasn't the VP Berlina LX sedans standard with IRS?
  16. #16
    jashdown91 is offline Jashdown?
    VS Acclaim S1
    Nov 2008
    live in ballina, thats near byron bay, everyone knows where byron bay is
    Quote Originally Posted by Da_rooster1980 View Post
    Oh come one. You must be kidding. Why is everyone asking whether a VS Berlina has IRS standard? I think there's a search engine on the internet named Google. It's highly useful and will always answer your question better than anything on here, in most cases.
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by sly_gen3 View Post
    so i guess a turbo locks both back wheels together? or is that a supercharger? thats what my cousin told me. Who also happens too be my girlfriend. She has 2 heads aswell.
  17. #17
    Jun 2005
    no they dont have it standard
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
  18. #18
    Wombles's Avatar
    Wombles is online now Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    For the brakes to pass a Roadie it needs to be able to stop in a certain amount of metres at a certain speed.
    They usually test it with a machine on the car and pedal..
    If it pulls up pretty well then it should be ok.
    But i've heard that the upgrade is well worth the money and pulls up so much quicker.
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
  19. #19
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Stopping that car quickly is really not what advanced and intelligent driving is all about. Safe driving requires that you maintain a good safe distance when travelling behind other traffic, don't go through yellow lights, don't disregard Give Way or Stop signs and always drive with complete consideration for other road users. Coming to a stop should be smooth and fully calculated with nothing left to chance. No need for sudden stops. Your standard car with standard brakes will be quite OK.
  20. #20
    Jun 2005
    Quote Originally Posted by Benboy View Post
    doesnt mean that better brakes are a bad idea. there are always morons on the road and you cant predict everything. what happens when a cyclist jumps out in front of you doing 10km/h on an 80km/h road, or someone turns in front of you and doesnt see you. if you can stop faster, then i dont see what the issue is
  21. #21
    VS executive
    Jun 2009
    Quote Originally Posted by stocky View Post
    doesnt mean that better brakes are a bad idea. there are always morons on the road and you can predict everything. what happens when a cyclist jumps out in front of you doing 10km/h on an 80km/h road, or someone turns in front of you and doesnt see you. if you can stop faster, then i dont see what the issue is
    %100 agree
  22. #22
    ryno_vrx's Avatar
    Nov 2008
    Mirani
    i'm with stocky on this one, it doesnt matter how good of a driver you are or how carefull you are theres always a chance for something unexpected or random to happen so i'm all for better brakes, go with the upgrade you wont regret it and who knows it may save a life
  1. My breaks work better in the wet????
    By patullose in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-12-2011, 06:14 PM
  2. Cigarette Breaks :|
    By 1991_Vn2nV in forum The Pub
    Last Post: 08-12-2008, 03:32 PM
  3. squeaky breaks VX
    By InnocentMJ in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-09-2007, 11:24 PM
  4. VE HSV breaks five second barrier!!!!!!
    By batemada in forum VE Holden Commodore (2006 - ?)
    Last Post: 26-08-2006, 01:32 PM
