Results 1 to 4 of 4
Thread: Does it sound like a relay problem to you?
    VS 97 Series II
    Oct 2007
    Whalan, N.S.W
    Question Does it sound like a relay problem to you?
    G'day guys,
    When trying to fix my centre consol gear selector light, yesterday. I tested the globe holder with the multimeter, and the probe must of touched the negitive, and shorted out the dash lights, heater/aircon control lights. I then checked number 16 fuse and it wasn't blown. I did notice however that the fuse was a 15 amp fuse, not a 5 amp. I checked the fuse holder with the multimeter and it isn't getting any power. Does it sound like a relay problem to you?
    Thanks in advance guys!
    Terry
    My new ride with some upgrades.
    www.teamfusion.info
    Head unit: Fusion CA-CD500 Front Speakers: Fusion PP-CM650
    Rear Speakers: FusionPP-FR6520 Subwoofer: Fusion PP-SW120 Amp For Front And Rear: Fusion PP-AM120040 Subwoofer Amp: Fusion PP-AM300010
    vs commodore
    Oct 2009
    Tamworth NSW
    If it was the wrong fuse,especially a higher amperage,it might have fried somthing else.Id check the fusible links in the fuse box under the bonnet.If your lucky it might be just one of them blown.Also I dont mean the fuses under there, but the fusible links,they are different coloured square things with a fusible link that you can see through a little window on them.
    VS 97 Series II
    Oct 2007
    Whalan, N.S.W
    Yeah I will check that out in the morning. Thanks heaps Brett!!!!!
    www.teamfusion.info
    VS 97 Series II
    Oct 2007
    Whalan, N.S.W
    It turned out to be a hair fracture in the fuse. That's the reason why I thought the fuse wasn't blown. The fuse was replaced and it all works now!
    Thanks guys!
    www.teamfusion.info
  1. VX no sound (TEL) Problem
    By tannie21 in forum Car Audio
    Last Post: 05-10-2009, 02:44 PM
  2. intermittent wipe relay? ticking sound
    By tororossi in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 09-09-2009, 09:33 PM
  3. Relay Problem
    By minux in forum Electrical Wiring / Questions
    Last Post: 04-11-2005, 12:59 PM
  4. Help! Relay problem in Berlina VT?
    By nuts in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-09-2005, 12:35 PM
  5. Problem with relay(s)Please help
    By shanhsv in forum Electrical Wiring / Questions
    Last Post: 04-09-2005, 04:53 PM
