Results 1 to 7 of 7
Thread: Trans help!!
    VR SS S2
    Dec 2008
    Tasmania
    Default Trans help!!
    In my VRSS auto when I sit on the brake and spool the rear tyres the auto plays up real bad I only spool them for a second then take off but when I do the auto revs out hard in every gear then SLAMS!! into gear and when it gets to 3rd really doesnt want to change into 4th the car stays like this til I stop it and start it again, engine light comes on for 15 seconds but no fault code logged?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Start saving those dollars now. Spooling is what will kill an auto real quick as you are simply overheating the trans oil between the clutch facings which leads to premature failure. It's good fun but unfortunately doesn't last too long.
    ryno_vrx's Avatar
    ryno_vrx is offline Donating Member
    VR HSV enhanced Berlina
    Nov 2008
    Mirani
    a good idea would be to stop spooling.... until you build a better gearbox
    whats the difference between my missus and my blower??
    well they both whine but the blower actually puts out
    Y-Series Senator Signature
    Jan 2006
    Willall Racing
    VR SS S2
    Dec 2008
    Tasmania
    if it was the trans slip code wouldnt it log a fault although I did read somewhere that Holden took the slippage code out as it was causing alot of problems
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If the engine light came on it should log a code. Check them again...the faults follow the 3 sets of 12's.
    vt s s1
    Mar 2009
    Box = GONE!
  1. [VIC] need someone to put trans into a car
    By Junny in forum Swap / Wanted to Buy / Trade
    Last Post: 12-07-2009, 09:03 PM
  2. is my trans ok
    By jakewaze in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-05-2009, 12:38 AM
  3. Auto Trans problem when hot - need a trans cooler ??
    By woteva in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2007, 11:41 PM
  4. Dec 97 VT Trans?
    By gwynmart in forum General
    Last Post: 22-05-2006, 02:18 PM
  5. trans
    By onequikvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-05-2006, 02:48 PM
